Taking door panels off?
They are held on my a few screws and quite a few clips. Screw on the interior door handle, pull handle, etc ... clips just come loose by LIGHTLY prying/pulling the panel away from the door.
Usually with door panels you will break a few clips. Just take your time and make sure all the screws are out and the removable clips. After that, just lift up and out and hope for the best. If you break a few clips you can get them at a dealership for cheap. Good Luck!
I noticed my door panel always come loose on the driver's side then i have pop it back in after closing my door 3 to 4 times i am def taking it to the dealer to get looked at.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si4279 »</TD></TR><TR><TD CLASS="quote">Usually with door panels you will break a few clips. Just take your time and make sure all the screws are out and the removable clips. After that, just lift up and out and hope for the best. If you break a few clips you can get them at a dealership for cheap. Good Luck!</TD></TR></TABLE>
if you break any clips you are doing it wrong, the worst that happens is it stays in the door and not in the panel. then you pop it out of the door and put it back in the panel.
