A/C Compressor Turning On and Off
Old Dec 18, 2006 | 03:38 PM
cleartouch33's Avatar
Default A/C Compressor Turning On and Off
what causes an A/C compressor to turn on and off at low rpms???
Old Dec 18, 2006 | 04:12 PM
chrisw85's Avatar
The pressure switch on the condensor could cause this at low RPM.
Thermal expansion valve perhaps too. If the lines get too cold compressor turns off to protect the system.
Old Dec 18, 2006 | 04:15 PM
Brick Top's Avatar
Default Re: (chrisw85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">The pressure switch on the condensor could cause this at low RPM. </TD></TR></TABLE>
yes, too low of an rpm can cause it to kick off and on. maybe to prevent stalling.
Old Dec 18, 2006 | 05:17 PM
frankist's Avatar
Default Re: A/C Compressor Turning On and Off (cleartouch33)
actually its suppose to engage the clutch on and off, depending on pressure. its perfectly normal for it to be cyling on and off, assuming you turned on your ac. for the low rpm, idling? or rpm drops while compressor turns on?
Old Dec 18, 2006 | 05:25 PM
Default Re: A/C Compressor Turning On and Off (frankist)
my a/c compressor is turning on and off constantly at idle/low rpms. this causes the motor to vibrate and act like it wants to stall. any idea whats going on?
Old Dec 18, 2006 | 05:31 PM
92civeg's Avatar
its fast cycling...it is low on freon....if you have the ac or defrost turned on
Old Dec 19, 2006 | 09:09 AM
Default Re: A/C Compressor Turning On and Off (92civeg)
my a/c is blowing cold. i did have my system recharged about a couple months ago but i'm not sure if its related. any other ideas?
greenteagod
20
May 8, 2014 08:25 PM
Muckman
Jun 1, 2011 10:59 AM
EJ8 GSR-T
Aug 8, 2007 09:48 PM
M15
48
Jul 22, 2006 10:11 PM
