block guard how neccesary for N/A
So yah im a noob first honda ive been a gm guy my whole life so i am new to open decks. questions is how beneficial are block guards to n/a setups i mostly see them on fi.
if it helps for my application im builiding in a nutshell is a d16y7 with mostly stock bottom end with 2 layer
y8 vtec head w/ (springs, retainers, flat face valves, medium profile cam, p+p)
port match IM to head and b18 tb
arp studs
tuning with obd1 on crome
aprox 10.6-10.8 static comp.
Will it benifit me or just impead cooling and not worth it
any input appreciated even a thread link already covering it
thanks
arp studs
thanks
im not runnin a d series i got a b20 mild built and i bought a kms blockguard i dont see how u can go wrong.. and i have not had a problem with over heating.. i think my thermostat(sp) is stuck open...
Whats up sea bass glad to hear you joined the honda world. I was a honda man the past 10 yrs who then went to GM (motor side of things) but even b4 hondas i was into mini trucks haha young and dumb. Unless ur squirtin on that b20 block the block gaurd has no use. Those things are garbage and are better left to be used as a fancy family big gulp cup holder.
thermo stuck open thats no good.. and yah i was thinking too that a block guard unecessary but thought id check first
any one else got some 2 cents to throw to the pot
speaking of the rod bolts i cant seem to find a definative answer to this but the arp bolts in stock rods do they require notching the block like h-beam rods from what i understandd the h-beam bolts dont clear without notching
b21c1
82
Jun 18, 2010 11:04 AM
