cant get the motor out.
Old Dec 18, 2006 | 11:37 AM
jikespingleton's Avatar
Default cant get the motor out.
ok so i got the axles out and everything is unbolted or disconnected. but now i cant figure out how to get the motor out of the car cuz the tranny is hittin the passenger side motor mount bracket. any ideas of how to get the motor past it?
Old Dec 18, 2006 | 11:42 AM
Rikter's Avatar
Unbolt the tranny from the motor?
-Rik
Old Dec 18, 2006 | 11:44 AM
Default Re: (Rikter)
no, thats twice as hard. its easier to pull out the tranny with the motor.
Old Dec 18, 2006 | 11:49 AM
DC2 Mang's Avatar
Default Re: (jikespingleton)
what year vehicle are you working on?
im assuming a DA because they are a pain in the *** to get the tranny side out
your best bet is going to be to support the motor on the drivers side more to tilt the engine at an angle to get the tranny side out
if not then put the motor on the ground and lift the car up high enough so you can pull the engine out from underneath it
Old Dec 18, 2006 | 11:53 AM
Default Re: (DC2 Mang)
no its a 94 gsr
Old Dec 18, 2006 | 11:58 AM
DC2 Mang's Avatar
remove the mount and then push and wiggle and get the motor at an angle so it will clear the chasis tranny mount and pull it out slowly having the other people move the motor around
you will need 2 extra people on each side of the engine to help guide it out, it is alot more difficult to put the engine in than it is to take it out
Old Dec 18, 2006 | 02:20 PM
95 integra's Avatar
You'll have to take off both lower mounts...incase you havent done that already. Then rotate the engine slightly (tranny towards the front) motor towards the back. The first time I did it, I got pissed and dropped the engine on a cart underneath it and then picked the chassis straight up. Given I had a big A-frame that allowed me the height to do that.
SOHC_Brian
Aug 10, 2004 10:58 AM
guttedsilvercrx
Jun 1, 2004 01:48 PM
NoLipRacen
Mar 6, 2004 09:29 AM
LudeyKrus
Aug 10, 2003 06:00 PM
