Unsure about my gas tank size
Old Dec 18, 2006 | 10:57 AM
Techy's Avatar
Default Unsure about my gas tank size
Well I have a 96 CX hatchback and I looked it up on Edmunds and it says 11.9 gallons. I don't believe it. Every time I fill up with my needle just hovering above empty I always put 9 gallons in. So what exactly is my gas tank's size. Could my needle be not reading right?
Thank you
Old Dec 18, 2006 | 11:09 AM
sicones's Avatar
Default Re: Unsure about my gas tank size (Techy)
11.9 gallons
Old Dec 18, 2006 | 11:16 AM
RBaluca.com's Avatar
Default Re: Unsure about my gas tank size (sicones)
Could be 9 gallons? I usually fill up on empty line at 35 litres. I'm not sure though.
Old Dec 18, 2006 | 11:23 AM
fmrprojects's Avatar
Default Re: Unsure about my gas tank size (re-marquable)
2 gallons is in the reserve
Old Dec 18, 2006 | 11:41 AM
old man neri's Avatar
You can keep driving well past the 'E', trust me, I know. Also remember that there is a difference between total fuel capacity and total usable fuel. But if you are unsure just look it up in your owners manual, it says it right in there.
Old Dec 18, 2006 | 11:48 AM
Techy's Avatar
Default Re: Unsure about my gas tank size (old man neri)
there's no owners manual. One of the things missing from the car when I bought it.
Old Dec 18, 2006 | 12:20 PM
blinx9900's Avatar
got the same car, i was once able to pum 10.88 gallons in, so i think its 11
Old Dec 18, 2006 | 02:15 PM
Taimaishui14's Avatar
In my Ex, I can run it down to well under empty, go fill it up and put in just over 10 gallons. Its got an 11.9 gallon tank though. One time I put in 11.2 gallons though :\
Old Dec 18, 2006 | 02:32 PM
ballerchild's Avatar
try driving your car until it dies on you and runs out of gas and then full tank it. that should answer your question.
Old Dec 18, 2006 | 03:16 PM
2coupes's Avatar
yeah, honda was smart and knew stupid people would run the car until past the E, so the gauge is meant to read E when you have a couple gallons left, the tank is 11.9 gallons
Old Dec 18, 2006 | 05:46 PM
Techy's Avatar
Default Re: (2coupes)
ok thanks, that explains it.
Old Dec 19, 2006 | 09:19 AM
seriot's Avatar
just curious is the 95 civic ex also the same size gas tank?
Old Dec 19, 2006 | 09:25 AM
2coupes's Avatar
Default Re: (seriot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seriot &raquo;</TD></TR><TR><TD CLASS="quote">just curious is the 95 civic ex also the same size gas tank?</TD></TR></TABLE>
yes, and if you want to see these specs for yourself, check the inside sticker in the glovebox
Old Dec 19, 2006 | 10:13 AM
egmatt93's Avatar
i dont have a glove box to find out
Old Dec 19, 2006 | 10:27 AM
wrinkles's Avatar
does anyone else have the problem where when it gets close to E it takes longer to start the car?
Old Dec 19, 2006 | 11:45 AM
Default Re: (K Stef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K Stef &raquo;</TD></TR><TR><TD CLASS="quote">does anyone else have the problem where when it gets close to E it takes longer to start the car?</TD></TR></TABLE>
Yes. The solution is to put the key to the 'on' for about 2-3 seconds and then start it. I think it has something to do with giving the fuel pump more time to prime.
Old Dec 19, 2006 | 01:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2coupes &raquo;</TD></TR><TR><TD CLASS="quote">yeah, honda was smart and knew stupid people would run the car until past the E, so the gauge is meant to read E when you have a couple gallons left, the tank is 11.9 gallons</TD></TR></TABLE>
Uhm... all cars are like that. When you hit E, you should have a couple gallons left, no matter what your driving.
Old Dec 19, 2006 | 01:46 PM
Syndacate's Avatar
Default Re: (Taimaishui14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Taimaishui14 &raquo;</TD></TR><TR><TD CLASS="quote">
Uhm... all cars are like that. When you hit E, you should have a couple gallons left, no matter what your driving.</TD></TR></TABLE>
This is true, and most cars, even have a LIGHT (my honda doesn't, boo) that's like "IDIOT, FILL UP UR TANK" and my '90 benz had a reserve tank, it would go like:
R...E.......1/2.......F
Ownage setup <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Techy &raquo;</TD></TR><TR><TD CLASS="quote">Well I have a 96 CX hatchback and I looked it up on Edmunds and it says 11.9 gallons. I don't believe it. Every time I fill up with my needle just hovering above empty I always put 9 gallons in. So what exactly is my gas tank's size. Could my needle be not reading right?
Thank you</TD></TR></TABLE>
First off, the Honda gas gauges are horribly inaccurate, they also got a foam float that makes them garble around w/ the gas level and make 'em change inaccurately.
Secondly, assuming it's 100% accurate, at "E" there is still ~1.5 - 2.5 gallons left.
Old Dec 19, 2006 | 08:56 PM
wrinkles's Avatar
sweet thanks old man neri, ill have to give that one a try
Old Dec 19, 2006 | 10:42 PM
wudini's Avatar
the gauge moves up towards full drastically when going downhill and turning left. i had a half of a tank once in a 12 story parking garage and by the time i hit bottom it read a full tank. the needle is retarded.
Old Dec 19, 2006 | 10:47 PM
I Shot 50 Cent's Avatar
Yes! Mine does the same thing.
Next time I get low I'm gonna try what the guy that quoted you first said and "prime" the pump a bit longer.
Good info, for me at least!
Old Dec 19, 2006 | 11:00 PM
Techy's Avatar
Default Re: (I Shot 50 Cent)
you know I've always done that out of habit from my last car. My brother told me to do that to help make the car start easier (now I know why) and plus it made my speedometer work correctly somehow for a few months until it was totally screwed.
I always turn my key to On not starting it, buckle up, then start it. I've always done it. It's just an unconscious motion. Same as me sticking my left foot on the brake in my mom's PT Cruiser or my manager's Corsica when trying to start it. Either that or I step on the floor real hard. Ouch.
NZXTInerTia
Jun 28, 2013 11:36 PM
Mondori
Aug 27, 2004 04:36 PM
E Swift
Mar 8, 2003 02:58 PM
WAFFLES
Jan 13, 2003 01:15 PM
Tiwe
Sep 12, 2002 05:59 PM
