exhaust leak
Old Dec 18, 2006 | 09:00 AM
EFresh's Avatar
Default exhaust leak
my exhaust is leaking, i looked at it and its leaking from where the end of the headers connects to the cat. my car sounds pretty beasty cause of that leak. i was wondering if theres a way to fix it cheap, on a budget. i was thinking of getting that high temp gasket maker stuff at pep boys and filling it around it but wasnt sure if it was safe or unless you guys know another solution. thanks in advance stock si exhaust
Old Dec 18, 2006 | 09:09 AM
HondaHeddie's Avatar
Default Re: exhaust leak (EFresh)
just get a new washer
there is a crushable cone shaped washer the is in that spring fitting
that part of the exhaust is made to flex
the stuff you are talking about will come loose as soon as you hit your first bump
Old Dec 18, 2006 | 09:12 AM
EFresh's Avatar
Default Re: exhaust leak (HondaHeddie)
where would i find those at? and wat is the price range?
Old Dec 20, 2006 | 09:38 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFresh &raquo;</TD></TR><TR><TD CLASS="quote">where would i find those at? and wat is the price range?</TD></TR></TABLE>
Not the best store I know but here it is
http://www.partsamerica.com/Pr...set=A
Old Dec 20, 2006 | 11:22 AM
wiZCo's Avatar
Stouts 'n' Scotch
Or OEM Honda: http://www.hondaautomotiveparts.com. I think it's somewhere around $10 or so. If you did not replace his gasket when istalling your header, you will need it now to get rid of the exhaust leak. And do it soon as in now.
spooty
Oct 12, 2008 08:02 PM
int3gra07
Dec 18, 2006 09:46 AM
douglaslovin
13
Sep 16, 2005 08:57 AM
CO Wagofan
11
Sep 17, 2004 09:51 AM
twisted_1
Aug 29, 2003 02:13 PM
