Anyone ever heard their axle "knock"? I think my inner CV is shot
Old Dec 17, 2006 | 11:00 PM
ProjectDarkBlack's Avatar
Default Anyone ever heard their axle "knock"? I think my inner CV is shot
well I started hearing a vibration noise while driving today, it is most noticable with the clutch in from 35-60mph. I drove it like 12 miles like this, has gotten somewhat louder. I replaced the inner CV boot 2 weeks ago, I put the tripod bearings in upside down, figured it out, and reinstalled it correctly before driving it. I also lost track of which bearing goes where (I think I did this on the other side a couple years back as well, never had an issue). I also have 242whp, which I regularly check lol. The noise sounds like a low knock, it is relative to my speed, I here it in the driverside axle area, and can feel it through the clutch peddle, I am pretty sure thats what it is. Any ideas or experiences?
I like having 2 cars
Old Dec 17, 2006 | 11:57 PM
Blk-dc2's Avatar
Default Re: Anyone ever heard their axle "knock"? I think my inner CV is shot (ProjectDarkBlack)
try just replacing the complete axle....they have remans or new ones out there...
Old Dec 18, 2006 | 01:47 AM
vladd's Avatar
you said yourself what the problem probably is. what exactly are you asking for? nobody's gonna go out and check your car for you. remanufactured axles suck. a friend of mine called me stupid for taking the time to replace my torn cv boots instead of just buying reman axles, until he bought a set. he then knew why i stayed away from that crap.
Old Dec 18, 2006 | 09:24 PM
Default Re: Anyone ever heard their axle "knock"? I think my inner CV is shot (civicdxtyper)
some experience with the problem, i.e. if it is what I think, if I have to get a new one etc. Why else would I ask?
Old Dec 18, 2006 | 09:31 PM
Coked GSR's Avatar
i had the same knock in my 01 gsr i replaced the cv shaft and it fixed it perfectly
Old Dec 18, 2006 | 10:30 PM
1uncleanDA's Avatar
Default Re: Anyone ever heard their axle "knock"? I think my inner CV is shot (Coked GSR)
yea i didnt get mine fixed in time and had to get a tow
Old Dec 19, 2006 | 05:40 PM
Default Re: Anyone ever heard their axle "knock"? I think my inner CV is shot (1uncleanDA)
ok looks like I have my work cut out. I jacked it up today and didn't notice anything but
new oil stains
Old Dec 19, 2006 | 07:01 PM
MRdc4's Avatar
I'm sure you already checked this, but are your wheels torqued correctly? we repainted my friends wheels on his project gsr and never retorqued the wheel after the paint had been pressed in place from lug. So it was making a knocking and we assumed it was his axle, but we realized it was only the loose wheel
Old Dec 19, 2006 | 07:34 PM
Default Re: (MRdc4)
it could be that, I didn't use a torque wrench this time... hmm...
Old Dec 19, 2006 | 07:40 PM
Default Re: (ProjectDarkBlack)
holy crap you were right,... I feel really stupid now. Usually I snug them up before I drop it down, then torque them at 80 with it on the ground. This time I just used the L bar and never rechecked it, it was the only wheel loose and the only one I took off the other week.
Old Dec 19, 2006 | 09:05 PM
MRdc4's Avatar
Ha ha well we left pretty dumb too, seeing how we both work for discount tire lol
Old Dec 20, 2006 | 09:36 PM
Default Re: (MRdc4)
ya I work at a shop too, I do some mounting and balancing once or twice a day...so ya.
what did I learn?
Use the torque wrench!
Old Dec 21, 2006 | 05:49 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I have done that 3 times to date, that is - work on car, put wheels back on, tighten lugs finger tight, drop car to ground, then go out and test drive but forget to tighten lug nuts (driving around with only finger-tight lug nuts ).
usually when your inner CV joint craps out, you'll know it by a severe vibration only while under load (throttle open). When you take your foot off the gas pedal the vibration should go away.
CHANCELLOR12
Transmission & Drivetrain
Sep 24, 2016 02:50 AM
Ferio4ya
Nov 25, 2009 10:57 AM
dvlsfan30
Nov 6, 2008 06:55 PM
cadet
Apr 22, 2005 06:24 AM
B00STidDc5
Jun 29, 2004 12:05 AM
