CRX rear DA disc swap. MC????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicfreak »</TD></TR><TR><TD CLASS="quote">i know the non-abs works... if i had that one i wouldn't be askingthis question... i wanna know if the abs/alb one could work & if it cant, why not?</TD></TR></TABLE>
How was I supposed to know that by your original post?
You can use an ABS MC but you have to bend the lines, not sure about the booster though.
I just put a 1" MC and BB off of a '94+ teg(abs, same as ITR) in my CRX.
I'll be running EX rotors(10.3", same as ITR) and '95 Legend GS Calipers(2 piston, same as ITR/NSX), and SS brake lines. (should be AMAZING)
1991 CRX Si compared to '94+ Teg 1"
You have to bend the lines like this-
Don't be scurred. they're not THAT delicate.
Flare the Integra fitting on there. (stock 10mm fitting will not work. This fitting is 12mm from CarQuest.)
End result:
OR
If you want to go the easy route, just buy a 1991 Civic EX Master Cylinder from Advanced auto or the junkyard. It's a 15/16" MC, and provides plenty of pressure to power your DA brakes. It bolts right up to your stock Brake booster, and all the lines match up just fine.
End result:
OR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swipe’d »</TD></TR><TR><TD CLASS="quote">wow that post was VERY HELPFUL, how tyte is the pedal?</TD></TR></TABLE>
Don't know yet. My motor should be getting back from my builder this week, so I'll drive it next week and let you know!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostwerks.com »</TD></TR><TR><TD CLASS="quote">OR...you can just go with the non abs DA MC. No bending of the lines, and with the complete DA brakes, it's exactly how it's supposed to feel. </TD></TR></TABLE>
Yep, but remember, you have to change the Brake Booster too, unless you can figure out how to get the MC to work upsidedown!
Otherwise, a full DA conversion is awsome.
Another helpful link to give you another idea.
I have the same mc in my crx and the pedel feel great, it does take a lot of vaccum to run it. When I hit the brakes when I am idling and the rpm will go up a little bit but, it is worth it. It is a little over kill but, I going to be running a fastbrakes 4 piston caliper soon.
Andrew Marquis you had it easy with no motor in the car you try is with one in the car it was a bitch trust me on that,
Modified by adeline at 5:08 AM 12/25/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrew Marquis »</TD></TR><TR><TD CLASS="quote">I just put a 1" MC and BB off of a '94+ teg(abs, same as ITR) in my CRX.
EX rotors are the same as DA/DC rotors and the ITR rotors are 11 inch
oh and thought the legend calipers are the same as NSX (minus the writing) they are not the same as ITR the ITR are single piston caliper (accord station wagon same)
and the ITR/legend set up will only work on a DA or 90-91 civic EX knuckle on an EF with the 11" redrilled rotor
but you can use the EX/DA/DC rotor on a si/dx knuckle with the ITR/wagon/nsx/legend caliper
Modified by CBEengineering at 12:26 PM 12/23/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicfreak »</TD></TR><TR><TD CLASS="quote">awesome, so all i need are 12mm fittings to the mc & to bent my stock hosses correct? so its not IMPOSIBLE to use it correct?</TD></TR></TABLE>
you dont need to cut the old fittings off I would just buy a 10-12mm adapter and not cut the line seems easier
ITR/siR calipers are the same with a piston that is about 2 inches...i got a pair of 96 itr calipers and crx siR calipers....
Legend/NSX calipers are almost the same where they are both dual piston but the Legend pistons are bigger. NSX calipers have heat vains, and a better caliper bracket designed for better cooling and the oh so cool "NSX" lettering
and the for those who dont want to change there BB i agree and just use the CIVIC EX MC which is 15/16 and mounts to your factory booster. and you can run a strut bar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBEengineering »</TD></TR><TR><TD CLASS="quote">
and the ITR/legend set up will only work on a DA knuckle on an EF
but you can use the EX/DA/DC rotor on a si/dx knuckle with the ITR/wagon/nsx/legend caliper</TD></TR></TABLE>
<FONT SIZE="5">This is false information.</FONT>
You can use a ITR/NSX/Legend/Accord Wagon caliper and caliper bracket with a 90-91 EX kunckle. Please don't say this won't work cause people will beleive it. It will require the use of a redrilled rotor.
It is correct that it will also work on either DA or EX kunckle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">
It is correct that it will also work on either DA or EX kunckle.</TD></TR></TABLE>
its not false its only half true
I just meant what he was doing wont work he will be about 1/2 " short on the rotor and I forgot about the 90-91 ex I was thinking the 92-95 ex sorry
oh and they both require the use of a redrilled rotor
but you can use the 10.3" rotor on a si/dx knuckle with the itr/legend calipers
I thought you need some spacer as well to line the rotor up?
to undo the 4 bolts of the brake booster...save your energy and use a 88-91 Prelude FI model MC bolts up and is 15/16 same with the 1991 Civic Ex MC...
