Zex Nos Question
after doing research on Nitrous for my type R i decided to go with the ZEx system..I am planning to run about only 55shots .Do i need any extra mods like fuel pump,injectors,purge valve or anything?plmk.thanks
dont go with a dry shot, your gonna fk your car up..... go with wet shot, its safer.....
run colder plugs....
[Modified by Jordo, 3:13 PM 5/12/2002]
haha, first of all, zex and nos are 2 different companies, b of all...if you wanna run a small shot (40-60) go with NOS's single fogger wet system. its basically like the dry setup, but its alot safer in that it injects nitrous AND fuel into the nozzle instead of strictly nitrous like the dry setup. if you stay around 40-60 shot, you should be able to keep the timing stock, just get colder plugs (i like NGK's BKR7E's)
good luck, and happy spraying
edit: i can't spell worth a ****
[Modified by spankaveli, 3:18 PM 5/12/2002]
[Modified by spankaveli, 4:23 PM 5/12/2002]
1990 CRX Si
26
Feb 9, 2006 04:56 PM
EFing8
Dec 19, 2002 07:59 PM
