Newbee Here....Need Help With My S2K...Comptech Supercharger....
Hello all,
I just bought an 03 S2k equipped with a Comptech Supercharger kit. The previous owner don't know much about the supercharger and it is running like crap. He's a rich guy basically that pays a shop to put on the supercharger on his car.
Well anyhow, the car runs fine under 3500rpm. When you boost, the check engine light comes on and throw a knock sensor code. I forgot the code but it was something like bank 1 knock sensor.
What is the problem here? Any help/advise/wisdom is need here!
THANKS!
THANKS!
Bank 1? There's only 1 bank of cylinders. The knock sensor is on the side of the engine block. Check connectivity, then check the 2 TDC sensors on the valve cover by each cam.
But why would it throw that code? Do I need a timing controll unit? Or comptech setup is supposed to run as is out of the box?
tek_civic
Aug 8, 2003 03:36 PM
