Brakes squeal on easy stops...and one wheel has much more dust than the other...what's wrong?
Old Dec 17, 2006 | 07:16 PM
erikiksaz1's Avatar
Default Brakes squeal on easy stops...and one wheel has much more dust than the other...what's wrong?
My brakes only started to squeal a few thousand miles ago. It's not always a consistent squeal, but it tends to happen when I'm lightly modulating the brakes--like typical street braking.
The pads have a good amount of meat on them, and I don't see any other visual problems. BUT, one thing that I do notice is that the passenger side wheel never has as much brake dust as the driver's side. Could it be that it's sticking? Even if that were the case, my car doesn't pull to a certain side when i brake hard...
If it is sticking, how do I fix it? Just lube the sliders?
Old Dec 17, 2006 | 08:41 PM
95 integra's Avatar
Default Re: Brakes squeal on easy stops...and one wheel has much more dust than the other...what's wrong? (e
Generally one side has more dust then the other (because of weight distribution maybe?). Either way, generally that squealing under light braking is just a metallic spot (ie carbon metallic brakes), however it is much much more common on cheap brake pads. Yes, the $7 autozone specials squeal and the $60 OEMs dont.
atkxt
Honda Civic (2006 - 2015)
Aug 27, 2013 10:31 AM
bobmugen
Mar 21, 2009 12:52 PM
EH3Civic
15
Nov 12, 2007 11:02 PM
92ehatch
Mar 23, 2006 07:06 PM
mikeds122
Sep 25, 2004 12:55 PM
