removing fusebox
how do i do it? i need to get some wires in the cabin, and from what i hear the best hole is behind the fusebox. I removed the 10mm bolt but soemthing else is holding it down and i cant seem to find it. is there an easier place to put wires through?
I've used that hole many times....
after removing the 10mm bolt, look behind the fuse box. you will see two tabs. press those toward the firewall, while lifting up on the fusebox. it will slide up.
