trottle angle
Old Dec 17, 2006 | 12:57 PM
kixcrx's Avatar
Default trottle angle
i need to know how to take off that trottle angle sensor cause the screws look kinda weird and i dont want to buy another TB
Old Dec 17, 2006 | 03:23 PM
Crx Jimmy's Avatar
Default Re: trottle angle (kixcrx)
cut a slot in it with a dremel or hacksaw and use a flathead screwdriver to unscrew, or if you had a jdm throttle body like mine was it has star(torx) bolts , you just need the right torx bit to remove
Old Dec 18, 2006 | 03:12 PM
kixcrx's Avatar
Default Re: trottle angle (Crx Jimmy)
where can i find the throttle sensor i just called the honda dealership and they said it was discontinued so where can i find it now
Old Dec 18, 2006 | 03:15 PM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kixcrx &raquo;</TD></TR><TR><TD CLASS="quote">where can i find the throttle sensor i just called the honda dealership and they said it was discontinued so where can i find it now </TD></TR></TABLE>
Scrap yard. They are all the same from 88-00 I beleive. I used one from an ITR on my 1st gen B16. I've also used on from an F22 on a GSR. They are coming to find. They usually are broken when you get them from an importer (easy sensor to break as it sits on the outside of the TB). It's an easy part to change. Make sure you angle it right. It should have 0.500 volts going thru it at warm idle.
StraightCivic
Mar 23, 2006 08:05 AM
R_type
May 25, 2005 05:55 AM
ALLMOTOR ARUBA
Jun 6, 2004 06:16 AM
093SiLude
Feb 2, 2004 04:28 PM
alkeener
Oct 26, 2003 07:25 PM
