fuel filter banjo bolt ?
Old May 12, 2002 | 10:48 AM
Mikey3000's Avatar
Default fuel filter banjo bolt ?
when you tighten the banjo bolt on top of the fuel filter, the holes are supposed to line up with the hose that goes to the fuel rail right? how do you make sure these stupid *** holes line up? i turned my key to the acc so the fuel pump primed, and fuel came squirting out of the banjo bolt area. i wanna figure out why.
Old May 12, 2002 | 11:29 AM
EP3_05's Avatar
Default Re: fuel filter banjo bolt ? (Boss Hogg)
Did you replace the metal seals when you changed the filter??
Old May 12, 2002 | 12:14 PM
rolow's Avatar
Default Re: fuel filter banjo bolt ? (91civic)
No the holes do not have to be inline
You are just missing the cruch washers or the old ones need to be replaced
[Modified by rolow, 9:14 PM 5/12/2002]
Old May 12, 2002 | 02:12 PM
Mikey3000's Avatar
Default Re: fuel filter banjo bolt ? (rolow)
i did get all new washers and used them. the holes don't have to line up?
Old May 12, 2002 | 03:35 PM
raene's Avatar
No. You'll notice if you pull it off that there's a space around where the holes are on the banjo bolt, so fuel will flow anyway.
Old May 12, 2002 | 05:01 PM
Mikey3000's Avatar
Default Re: fuel filter banjo bolt ? (raene)
ok. i took the banjo bolt off, put teflon paste on it, retorqued it to spec and it still sprays fuel. only this time, it sprays it in a different direction than last time. what could this possibly be? could it be that my fuel pressure is too high? i have a fpr which i don't know what the setting is on.
[Modified by Boss Hogg, 11:33 AM 5/13/2002]
Old May 12, 2002 | 06:52 PM
t's Avatar
t
Are you sure you have both crush washers? one in between the filter and fuel line, and than another between the fuel line and the banjo bolt
Old May 13, 2002 | 05:12 AM
Mikey3000's Avatar
Default Re: fuel filter banjo bolt ? (t)
yes both crush washers are on and the washer under the relief bolt is on too.
Old May 13, 2002 | 05:44 AM
Daemione's Avatar
. . . . and it still sprays oil.
Where exactly is it spraying out of? All I can think of is that you've a bum washer.
Old May 13, 2002 | 07:34 AM
Mikey3000's Avatar
Default Re: fuel filter banjo bolt ? (Daemione)
oops i meant fuel of course. it's spraying from right under the head of the banjo bolt. the washers are new. you think i should try switching the two washers around and see what happens?
Old May 13, 2002 | 10:29 AM
rolow's Avatar
If you are using crush washers and not plane old washers and it's tq to helms
then every thing should be cool.
Do the banjo bolt or fitting have any marks on them I mean is the crush washer
making good cotact?
Old May 13, 2002 | 06:16 PM
Mikey3000's Avatar
i would think that they are making good contact. i have no idea what could be wrong. could it be that the banjo bolt is broken under the head (since that's where it's spraying from)? i can't see any holes or anything though. i'm totally stumped.
[Modified by Boss Hogg, 10:17 PM 5/13/2002]
Old May 16, 2002 | 11:53 AM
rolow's Avatar
Did you ever find out what was wrong?
Old May 16, 2002 | 11:59 AM
Mikey3000's Avatar
no but i've ordered a b&m fuel pressure gauge kit. that should come tomorrow. it comes with a new banjo bolt. i'm sure that'll do the trick. if it doesn't, i'm sellin' this pos.
Grnade
13
Nov 16, 2004 08:38 PM
onePOINTsix
Sep 4, 2003 08:24 AM
cvc323
Jun 29, 2003 11:09 PM
95GS-R
Sep 5, 2002 03:47 PM
