OBD 2 to OBD 1 Catalyctic Converter Question
Hey guys i have a question i have a 2000 gsr with the obd1 conversion on it. I wanna put a test pipe on but i noticed that there is a second o2 sensor in the cat. Is this sensor disabled since i have an obd1 ecu?
the OBD1 computer wont be looking for it, so you wont have any cel codes. However, alot of test pipes have an o2 sensor bung welded in anyway, so u can leave it in there if you want, or replace it with a wideband and run an a/f gauge
well i have the omni test pipe and the o2 bung is on the wrong end of the pipe. thats why i was wondering if i even have to use it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">No, you don't. </TD></TR></TABLE>
x2
ODB1, only one o2 sensor, so just plug up the second hole.
x2
