WTB big brake kit for civic 92-00 with 262mm rotors
I have that wilwood kit (12.19") dynalites with rear disk swap complete - front and rear stainless lines - unslotted rotors on front - drilled rears. If you are interested hit me up.
Have a SSBC kit if you are interested. Link Also 262mm is about 10.5 inches. Probably looking for around a 305mm kit if you are looking at 12.19 inches
Make sure you know that the cheaper Wilwood brakes need to be rebuilt often as there is not rubber seal for the pistons, hence the cheap price. Plus on a side note, I have two different brake systems that I have seen side by side (four piston caliper and the SSBC). The SSBC brake pad surface area is 1/3 larger then most 4 piston calipers that are out there. Also the rotors are extremely thick which enhance heat dissipation (less chance of warping under heavy braking), so they are quality build and are probably the best setup that I have seen.
got some brembo gran turismo big brake kit off my 94 integra 4x100 show car...i had it on my show car for about 6 month...time to sell cuz i'm switching rims.....brake kit also comes with brembo rear matching disc too....whole kit is complete to bolt right on....paid over $2500 brand new...now only $1700...
