high compression valves?
Old Dec 17, 2006 | 08:24 AM
neofreak's Avatar
Default high compression valves?
does anybody know how much omni flat faced valves will decrease the combustion chamber volume on a B16? i need to know so i can figure out what i want to do with the rest of my engine
Old Dec 17, 2006 | 01:16 PM
Combustion Contraption's Avatar
Omni states its usually around .2-.3 but its different in every engine. In some heads, you may even lose compression.
Old Dec 17, 2006 | 03:44 PM
neofreak's Avatar
Default Re: (Combustion Contraption)
i know thats what they say the Compression Ratio increse is. what i'm looking for is what the change in combustion chamber volume is. i dont have the tools to measure it
Old Dec 17, 2006 | 04:26 PM
You mean as in CC increase/decrease? If you dont have the tools to measure it but still want the info, take it to someone who does have the tools, dont expect to find the answer on HT.
Old Dec 17, 2006 | 05:50 PM
neofreak's Avatar
i was just wondering if anyone else has done it, thats all
Old Dec 17, 2006 | 05:57 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (neofreak)
It should reduce the combustion chamber volume by approximately 1-1.2cc or so. This will give you about a .2 bump in compression.
Old Dec 17, 2006 | 07:22 PM
neofreak's Avatar
Default Re: (00Red_SiR)
thank you
Old Dec 17, 2006 | 10:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">It should reduce the combustion chamber volume by approximately 1-1.2cc or so. This will give you about a .2 bump in compression.</TD></TR></TABLE>
Yea, in the end it will usually raise static CR by about .2-.3, but unless you measure it, youll never know.
castanagajt
16
Oct 5, 2009 04:39 PM
94typeR
Apr 10, 2007 11:42 AM
Mikes2000civicsi
Jan 22, 2007 12:37 PM
Eg2Project
Sep 24, 2006 11:48 PM
Malice
Jul 5, 2002 12:17 PM
