Size and Offset question
I'm curious to know if this size rim w/ this offset will fit an 99-00 Civic Coupe
15"x7.5" at +38mm offset
and if not how off would they be?
and does anyone have pics of a rim like that on one
Is this for street tires, or track tires?
If it's for street tires, I sure wouldn't get those. They're too wide. On a '99-00 Civic with 15" wheels, you need 195/55-15 or 205/50-15 tires. 195/55-15 is only approved for wheels 5.5-7.0 inches wide. And while 205/50-15 is approved for 5.5-7.5, they're going to look really stretched onto 15x7.5.
Get some 15x6 or 15x6.5 and you'll be good to go.
well it is for the street
but my main concern is the tire rubbage...and if i need to roll the fenders at all
and im not worried bout tire stretching...i kinda like that look...i just wanna know f that size will fit
basically im very interested in teh Drag DR-20 wheels and want to know if they will fit...they are only available in 15x7.5 and has 38mm offset
this is wut the rims look like
do you have 14's on now or 15's on now????????if you have 15's then take a tape measure and add another .75 inches from the outer lip to the outside of the fender to see what is going to rub...if you have 14 then take the tape measure from the outer lip to your fender 1.50 inches and you will see how much room you have....hope that helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by conv2vtec »</TD></TR><TR><TD CLASS="quote">15"x7.5" at +38mm offset</TD></TR></TABLE>
They'll fit ok, but you won't be able to go too low on those wheels. These are 15x7 +38, make you own judgement:
slammed_93_hatch
Jul 16, 2003 06:44 PM
