A few questions about my welder
Im waiting on my Miller 250dx tig runner package to arrive from cyberweld. I was wondering if anyone knew info about the torch i will get with it so i can buy some gas lenses for 3/32 and 1/16 tungsten?
yes it does.
http://store.cyberweld.com/milsyn250dxt.html
# COMES COMPLETE WITH:
# Syncrowave 250DX
# Integrated Cooler
# No. 37 Running Gear
# Remote Foot Control
# * Completely Assembled *
# Dinse connection kit (195 303)
# 25 ft, 250 amp water-cooled DB20M25R Diamondback™ torch
# Work clamp
# 10 ft gas hose
# Regulator/flowmeter
# Cable cover
# AK-4 accessory kit
# Syncrowave 250DX
# Integrated Cooler
# Work clamp
# 10 ft gas hose
# Cable cover
For 9 series air-cooled torch or a 20 series water-cooled torches, a standard or large gas lens (commonly called a stubby) provides good gas coverage. This smaller torch profile increases operator comfort by reducing the overall torch weight and allows access on tighter joints.
ok so now what type should i buy and where from, sorry for the questions, im just in a rush to have all of my parts since my welder is in transit and im unfamiliar with some of the intricate details.
My bad, I didn't see that you mentioned that you got the package.
Definitely get a regular gas lens and a couple different cups to go with it. Any welding shop or online place will have listings. Look for a #9 or #20 (they use the same components) torch and order these parts:
Small 53N series Gas Lens Cups (choose your cup size)
Small 45V series Gas Lens (choose your tungsten size)
13N Series Collet (choose your tungsten size)
Those three things will havve you setup for gas lens. GThe problem with cyberweld and most online places is that they make you order so many. Try to find a local welding shop and get the parts there for your #20 torch. That way you can get only one and try out different cup sizes.
Good luck.
Good luck.
whats the difference between the small, and large gas lense? Ive been reading but im jsut not sure of the differences, i have read stuff about jumbo lenses and stuff, i ahve a hookup on welding materials through a freind so i just need to know exactly what to order.
Cyberweld lists it like cause they are retarded. The medium and large gas lens on their site are for #17 and the like torches. The "small" gas lens is for #9 and the like torches.
I don't believe that a larger gas lens is available for the #9.
