SOHC DYNO - D16Y7 @ 6psi... Garrett 42/48 T3
Old Dec 16, 2006 | 08:55 PM
DragWerks's Avatar
Default SOHC DYNO - D16Y7 @ 6psi... Garrett 42/48 T3
D16Y7 (2000 Civic DX) @ 5-6psi
Everything else stock except:
D16Z6 Intake Mani
240cc Injectors
Garrett .42/.48 T3 (internal w/g)
2.5" D-Pipe + Exhaust
sorry no engine pics...
Old Dec 16, 2006 | 10:19 PM
Boosted B6teen's Avatar
Default Re: SOHC DYNO - D16Y7 @ 6psi... Garrett 42/48 T3 (DragWerks)
Nice number for that set-up
Old Dec 16, 2006 | 10:38 PM
Oleg's Avatar
Yes! I bet you are as exited as i was when i got my car tuned . Go kick some ***!
BTW, run it on the track, see what numbers you'll get....you are not slow anymore....
Old Dec 16, 2006 | 11:10 PM
DragWerks's Avatar
Default Re: SOHC DYNO - D16Y7 @ 6psi... Garrett 42/48 T3 (Oleg)
^^^ , actually I tuned the car. I just posted it so people could have an idea of what their dx sohc is capable of, on a budget (vs. swap, etc.) The car is actually on the market, but this is an example of how for $500-1000, you can have the power/torque of an h22, ITR or K-series swap and be just as if not more reliable.
Old Dec 17, 2006 | 06:40 AM
boosted k20's Avatar
stock injectors? how much fuel pressure were u run n
Old Dec 17, 2006 | 11:08 AM
Jim Truett's Avatar
Default Re: SOHC DYNO - D16Y7 @ 6psi... Garrett 42/48 T3 (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">stock injectors? how much fuel pressure were u run n</TD></TR></TABLE>
I would bet he still has the stock regulator. I have made that much on 240s with stock pump and regulator. They just end up maxed out.
Old Dec 17, 2006 | 12:01 PM
Ek_man97's Avatar
good numbers...
Old Dec 17, 2006 | 01:00 PM
DragWerks's Avatar
Default Re: SOHC DYNO - D16Y7 @ 6psi... Garrett 42/48 T3 (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">I would bet he still has the stock regulator. I have made that much on 240s with stock pump and regulator. They just end up maxed out.</TD></TR></TABLE>
correct... stock everything, funny thing is they still had more in them...
Old Dec 17, 2006 | 04:38 PM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragWerks &raquo;</TD></TR><TR><TD CLASS="quote">
correct... stock everything, funny thing is they still had more in them...</TD></TR></TABLE>
think about it, it doesnt matter turbo or n/a flow is flow and fuel consumption needed to meet x hp is the same. im sure there are plenty of all motor b series guys making 170whp on stock injectors.
what does a 240cc injector max out at anyway? a little shy of 200 whp on around 3 bar fuel pressure?
Old Dec 17, 2006 | 04:51 PM
DragWerks's Avatar
Default Re: SOHC DYNO - D16Y7 @ 6psi... Garrett 42/48 T3 (blackeg)
^^^ you can probably theoreticaly make more hp all motor then you can boosted at the same fuel level since you run a boosted tune fatter (i.e. 12:1 vs. 13.5:1 all motor) than a n/a tune. I tuned a stockish b20/vtec that made 174whp on 240cc injectors and they also had more fuel left in them. Come to think of it, the car was only revving to 7500rpm, had it revved higher, that may have done a number on the injectors
sohc_turd
Jun 30, 2007 01:20 AM
mr_hahn73
Oct 29, 2005 05:53 AM
turboeg77
Oct 19, 2005 03:39 PM
oxSLEEPERxo
Apr 28, 2005 07:12 PM
Pritos
Apr 29, 2002 05:59 PM
