A/C switch to arm nitrous?
Old Dec 16, 2006 | 05:44 PM
91tealhatch's Avatar
Default A/C botton to arm nitrous?
i was wondering how i could arm my zex kit with my A/C button. i think it would be cool and stealthy. does anybody know how to do it? thank you!!!
Modified by 91tealhatch at 12:31 AM 12/17/2006
Old Dec 16, 2006 | 06:22 PM
Default Re: A/C switch to arm nitrous? (91tealhatch)
Old Dec 17, 2006 | 12:47 AM
i need help
Old Dec 17, 2006 | 03:43 AM
4thgenhtch's Avatar
In the engine bay there should be a relay that clicks on and off when you hit the a/c switch... Probe the wiring with a test light.. See if it has a positive or negative pulse; With a Bosch Relay Tap the output from the factory a/c relay and run it to pin 86 then run pin 85 to the oposite of whatever your getting from the factory relay either + or a -... Run the Arm wire off the nitrous controller to pin 30 then run + to pin 87 ..
PR8urVtec
Engine Management and Tuning
12
Jan 3, 2017 03:49 PM
zCivic
Mar 3, 2004 11:31 AM
bew
Sep 11, 2003 09:17 AM
CimorelliCRX
May 26, 2003 09:32 AM
senpai
Nov 7, 2002 04:30 PM
