w/ ITR's, JDM 4-1 and stock exhaust q
With the R, in order to use a JDM 4-1 header and stock catback,
how do you do it?
just get a different size cat----what size?
thanks
how do you do it?
thanks
carsound 94066 i believe.
needs to be 2.5" to 2.5", but the ID match of yoru b-pipe and your cat will be pretty bad. stock b-pipe ID is 1-3/4", but it will bolt up.
i'm referring to the stock ITR exhaust....
which is 2" diameter right?
will that work?
im not so sure which cat i have right now, but i got it as a package with the JDM 4-1....so should that be right?
the cat is a carsounds unit, 2.5" diameter, and is 16" long....that work?
will that work?
You get a 2" connector welded on to one side of the cat. and then a flared end for the sid ethat hooks in to the header.
Talk to Mike @ IPSRacing (www.ipsracing.com) or Mark @ Landspeed (www.landspeedracing.com) about getting a carsound cat. to fit for you. It's relatively easy.
The cat should bolt up to the stock b-pipe without a problem. However, there will be a mismatch in the diameter's of the cat outlet and the flange of the b-pipe. Dave at SMSP sells a reducer flange that will taper the entrance to the b-pipe from 2.5" down to the 2.25' of the rest of the piping. It installs with a small amount of cutting and welding. HTH.
I highly recommend Dave's (SMSP) reducer flange. I got mine in stainless, it's sweet! He even sent it out on a Saturday!! Dave rocks!
schumi
Jul 23, 2005 09:14 AM
Hukd Up
Apr 2, 2003 05:51 PM
