CATBACK!
Old Apr 1, 2006 | 06:09 AM
h0ndaDC2's Avatar
Default CATBACK!
hey guys,im planning to get a apexi GT spec exhaust or tanabe racing medalion.CAT BACK.and i was just wondering if it would fit the jdm header 2 1/2 collecter.
Old Apr 1, 2006 | 12:38 PM
h0ndaDC2's Avatar
i meant,can u put the jdm header with the stock cat?
Old Apr 1, 2006 | 12:54 PM
92TypeR's Avatar
FSAE
Default Re: (h0ndaDC2)
No. The USDM cat has a 2.25" flange, the JDM ITR header has a 2.5" collector. Will not fit.
Easiest solution is to get something like an Omni testpipe that goes from 2.5" to 2.25" (if you're using the stock exhaust), or straight 2.5" if you're going with an aftermarket catback.
The JDM ITR cat will work also, but is just as much of a restriction as the USDM ITR cat.
Old Apr 1, 2006 | 12:59 PM
itr1244's Avatar
Default Re: CATBACK! (h0ndaDC2)
ok .. so you have 2.5" header and you are getting a cat back that's not stock piping size
so that means you cant use stock cat..
all you need is a 2.5" cat that will fit your header and your cat back
jeremy_dane
Feb 20, 2009 09:07 AM
VTEConly
Jul 1, 2007 06:11 PM
00-501itrspec
Oct 13, 2005 08:52 PM
iBear
Oct 1, 2004 09:37 PM
comptechgsr
May 12, 2002 10:44 AM
