Honda S2000 Honda S2000
Oil in exhaust
Old Dec 16, 2006 | 10:45 AM
Speed Monkey's Avatar
Default Oil in exhaust
So I have been seeing a little bit of white smoke on startup. I thought that it was b/c of the cold. Today I let the car warm up at idle and revved it up to 6k and saw lots of smoke.
I looked in the tailpipe and there is black oil residue. I am thinking either valve seals or head gasket. The car is an 01 w/ 28k mi. Runs fine, have not noticed power loss or anything. No overrevs or mods. Any ideas or advice?
Old Dec 16, 2006 | 10:53 AM
cmdr430's Avatar
Default Re: Oil in exhaust (Speed Monkey)
where does the car live? outside or garage at night?
it still sounds like moisture build up in the exhaust system, that has not burnt out completely....
after letting it idle you say it still happens, correct? what about after you have driven it for 30 mins. or so?
does it still appear to smoke?
Old Dec 16, 2006 | 12:01 PM
It lives in a garage, but not heated. And WA is a little wet. After idling for a while the residue was black and slick. I drove for a little while and no smoke (maybe it just wasn't warmed up all of the way). But after driving a bit (and WOT a bit), the inside of the tailpipes are dry but sooty. I had just wiped them out. Is this normal or am I running rich? Thanks.
Old Dec 16, 2006 | 12:04 PM
cmdr430's Avatar
Default Re: (Speed Monkey)
sounds normal to me....
what brand of oil are you using? regular or synthetic?
Old Dec 16, 2006 | 01:09 PM
Mobil 1 and K & N filter.
Old Dec 16, 2006 | 05:41 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed Monkey &raquo;</TD></TR><TR><TD CLASS="quote">It lives in a garage, but not heated. And WA is a little wet. After idling for a while the residue was black and slick. I drove for a little while and no smoke (maybe it just wasn't warmed up all of the way). But after driving a bit (and WOT a bit), the inside of the tailpipes are dry but sooty. I had just wiped them out. Is this normal or am I running rich? Thanks.</TD></TR></TABLE>
dry and black soot? yeah, it's normal.
look for blue smoke if under wot, that would be burning oil
Old Dec 16, 2006 | 08:38 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: (iam7head)
White smoke would be coolant... no?
Old Dec 16, 2006 | 08:47 PM
Nishant's Avatar
Default Re: (FR-MOB: Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">White smoke would be coolant... no?</TD></TR></TABLE>
yes
Old Dec 16, 2006 | 09:02 PM
* B A N N E D *
Default Re: (Mr. Nishant)
Water jacket head gasket intake manifold throttle body... no?
Old Dec 17, 2006 | 07:54 AM
b20integrapower's Avatar
the black stuff is just carbon build/dirt build up. and when it mixes with the moisture..it may resemble something a little similar to oil. im sure you are fine.
91b18a1ls
Aug 26, 2012 12:46 AM
bpfergu
Mar 5, 2012 05:27 PM
tony7626
Mar 27, 2009 10:48 PM
reed857
Dec 8, 2005 03:56 PM
