Suspension & Brakes Theory, alignment, spring rates....
~~~~~~~~~~~~SIMPLE ??? ON SWAY BARS~~~~~~~~~~~
Old Dec 16, 2006 | 08:54 AM
chinoty's Avatar
Default ~~~~~~~~~~~~SIMPLE ??? ON SWAY BARS~~~~~~~~~~~
can anyone give me the spec on EG/EJ sway bars compare to DC compare to ITR on both front and rear??? i just bought two sway bar front and rear off an integra at the junk yard. it has a large sway bar in the lower rear that i have never seen before. its all black as i know of. i measure it and its a little off 1'' inch in diameter but a little over 3'' inches in radius. dont know if its stock itr or what but really need some help. thanks.
Old Dec 16, 2006 | 09:17 AM
BlueIntegraBoy's Avatar
Default Re: ~~~~~~~~~~~~SIMPLE ??? ON SWAY BARS~~~~~~~~~~~ (chinoty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chinoty &raquo;</TD></TR><TR><TD CLASS="quote">can anyone give me the spec on EG/EJ sway bars compare to DC compare to ITR on both front and rear??? i just bought two sway bar front and rear off an integra at the junk yard. it has a large sway bar in the lower rear that i have never seen before. its all black as i know of. i measure it and its a little off 1'' inch in diameter but a little over 3'' inches in radius. dont know if its stock itr or what but really need some help. thanks. </TD></TR></TABLE>
This is not possible...
USDM models only (fr/rr)
97-01 Integra Type-R (24mm/22mm)
94-01 Integra GSR (24mm/14mm)
94-98 Integra LS (22mm/13mm)
99-00 Integra LS (24mm/13mm)
92-95 Civic EX ABS (21mm/13mm)
Old Dec 16, 2006 | 12:13 PM
chinoty's Avatar
Default Re: ~~~~~~~~~~~~SIMPLE ??? ON SWAY BARS~~~~~~~~~~~ (BlueIntegraBoy)
im refering to 3'' inches all the way around the bar. but the diameter at 1'' inch, btw it was found on a 97 4 door gsr both front lower / lower rear. if all OEM 94-01 models are only 14mm in rr then the one i found is much bigger than 14mm. i would assume the 14 mm is the very thin one the size of a finger. any other input. thnx.
Old Dec 16, 2006 | 12:53 PM
archmage's Avatar
Heheh...
circumference = pi(d), so it was ~3.1416(x) that Diameter you measured, and the radius was HALF that diameter.
You must be REALLLY overworked (or underworked).
GSR-REX
Sep 7, 2010 06:28 PM
triple
May 23, 2006 03:45 AM
calinomad
13
Apr 7, 2006 10:11 PM
phantom_sol
Oct 31, 2003 11:34 AM
deviant1
17
Nov 3, 2002 11:40 PM
