My Eg wont start help please
Old Dec 16, 2006 | 08:06 AM
jayzonmyfeet's Avatar
Default My Eg wont start help please
ok i have a LS turbo eg hatch, it wont start , but i can pop start it , if im trying to start it normaly i get nothing at all, but i have power in the car so its not the battery , maybe the ground on the starter is loose ? and other suggestions i know it could be 100 things but some quick suggestions would be appreciatted
Old Dec 16, 2006 | 08:07 AM
deadline's Avatar
u check the starter ??
Old Dec 16, 2006 | 08:08 AM
hondachris1994's Avatar
clutch safety switch, just bypass it
Old Dec 16, 2006 | 08:10 AM
Default Re: (deadline)
how could i check the starter
Old Dec 16, 2006 | 08:14 AM
Default Re: (hondachris1994)
how do i bypass my clutch safety switch??????
Old Dec 16, 2006 | 08:35 AM
here's a link but the pics are gone https://honda-tech.com/zero...63444
Old Dec 16, 2006 | 08:49 AM
tietze's Avatar
Default Re: My Eg wont start help please (jayzonmyfeet)
clean battery terminals
check grounds from batt to body, body to tranny
PUT CAR IN NEUTRAL
On the starter solonoid, use a jumper cable to connect the large wire, (which goes to batt) to the "spade" connector on the solonoid. This should make starter engage and crank the engine, if the solonoid and starter are good. This bypasses f41, f39, ignition switch, starter cut relay (clutch interlock), so if you missed the part about putting the car in neutral, it can run you over!!!
Old Dec 16, 2006 | 09:08 AM
Default Re: My Eg wont start help please (tietze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tietze &raquo;</TD></TR><TR><TD CLASS="quote"> so if you missed the part about putting the car in neutral, it can run you over!!!
</TD></TR></TABLE>if your a dumbass u should b ran over , Ive had my switch bypassed for the last 2 yrs with no issues
Ethan Ashley
Sep 11, 2018 07:06 PM
Jmx305
12
Dec 9, 2013 03:20 AM
Offspring EK
22
Dec 9, 2009 04:55 PM
B18CivicEH2
May 6, 2009 05:29 PM
curiousgpnoy
Jun 25, 2003 08:43 AM
