head bolt torque specs?
Old May 12, 2002 | 08:12 AM
dogpile5's Avatar
25 Year Member
Default head bolt torque specs?
need the head bolt torque specs for a b16a. i am aware you are supposed to torque the bolts in *stages*, so please list all applicable specs. thanks in advance!
Old May 12, 2002 | 12:34 PM
Redline130's Avatar
Default Re: head bolt torque specs? (dogpile5)
The first torque stage is to 22ft-lbs. Then 61ft-lbs.
Sequence:
distributor side intake 9 5 1 3 7 timing belt side intake
distributor side exh. 8 4 2 6 10 timing belt side exh.
Sorry for the ghetto diagram, but hopefully it helps somewhat. 1, being the first head bolt to tighten in the sequence and 10 the last. This is via the Helms.
Old May 12, 2002 | 09:35 PM
Rocket's Avatar
Default Re: head bolt torque specs? (cyber13)
This sounds like over kill but I do the torque sequence 3 times. Tighten, loosen, tighten....you get my drift. At the third time the torque readings become nice and consistent. Sounds like a pain in the butt , but it is also relaxing...Just turn and click.
This produced nice results for me.
Old May 12, 2002 | 10:14 PM
Kamin's Avatar
just to clean that up a little
9 5 1 3 7
8 4 2 6 10
Old May 13, 2002 | 07:35 AM
dogpile5's Avatar
25 Year Member
Default Re: head bolt torque specs? (KAMiN)
much thanks! now if i can just find sponsors for the arp head bolts fund....
Old May 13, 2002 | 07:37 AM
Rocket's Avatar
Check the best buys. I was going to check in on some prices for these.
Old May 13, 2002 | 07:38 AM
dogpile5's Avatar
25 Year Member
Default Re: head bolt torque specs? (Rocket)
i know summit racing sells the b16/b18c head bolt package for 118 + shipping. if anyone know anything better than that, please post it!
Speedypablo
Honda Civic (2006 - 2015)
Mar 3, 2018 08:21 PM
EG93si
Dec 30, 2005 06:16 PM
kingteghelm
Jun 15, 2005 10:56 AM
Four Door LS VTEC
Feb 13, 2003 05:13 PM
