Honda S2000 Honda S2000
Cam chain sprocket bolt doesnt go in
Old Dec 15, 2006 | 11:51 PM
teknoracing's Avatar
Default Cam chain sprocket bolt doesnt go in
My friend took his head off to replace it with a 3mm headgasket to prepare for his GT35 turbo and everything is going back on fine but the bolt that goes into the cam chain sprocket doesnt go in all the way. He says as he starts to turn it, you can see shavings. What does he do? is there a certain way to get this last bolt on??
Old Dec 16, 2006 | 10:28 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: Cam chain sprocket bolt doesnt go in (teknoracing)
1) Chain tension
2) Special Purpose Bolt
Old Dec 16, 2006 | 11:33 AM
Default Re: Cam chain sprocket bolt doesnt go in (FR-MOB: Projekt)
i dont understand. Again, its not my s2k, maybe he will know what it means
Old Dec 17, 2006 | 09:04 AM
fperra's Avatar
In one of my older builds I had a Cometic 3 mm gasket and the sprocket bolt went in just fine. Did your friend remove the cam chain tensioner? If he didn't there is no way to get it in.
Old Dec 17, 2006 | 06:42 PM
* B A N N E D *
Default Re: Cam chain sprocket bolt doesnt go in (fperra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fperra &raquo;</TD></TR><TR><TD CLASS="quote">In one of my older builds I had a Cometic 3 mm gasket and the sprocket bolt went in just fine. Did your friend remove the cam chain tensioner? If he didn't there is no way to get it in.</TD></TR></TABLE>
Thank you!
Old Dec 17, 2006 | 08:10 PM
No he didnt remove the cam chain tensioner. He figured it out after i posted. I guess cause it was almost 1am and he is trying to prep his car for that sweet sweet turbo. Will post pics soon when he's done.
HypL
Apr 6, 2020 10:10 AM
B-serius
Aug 10, 2009 02:21 PM
onemore
Jul 9, 2008 03:22 PM
dblkack
Mar 16, 2005 05:24 PM
1.8EG-T
Nov 29, 2001 07:34 PM
