Clutch Issue with my JDM B16
Old Dec 15, 2006 | 11:18 PM
TurboTagTeam's Avatar
Default Clutch Issue with my JDM B16
After driving for about 20mins tonight my tranny began to be more difficult to shift and it was grinding when forcing it into gear. My tranny was perfect, no grinds at all. Now all of a sudden it is really hard to put it into gear. If I rev-match the gears perfectly, it will go in smoothly. Also, the pedal pressure feels fine so I'm thinking that it can't be a problem with the slave or master cylinder. Any thoughts? Replace the clutch???
Recap:
Hard to shift
Normall pedal pressure
clutch holds fine=does not slip
Old Dec 16, 2006 | 02:46 AM
slkleltlclh's Avatar
Default Re: Clutch Issue with my JDM B16 (TurboTagTeam)
low fluid?
Old Dec 16, 2006 | 08:18 AM
nsxmatt's Avatar
Default Re: Clutch Issue with my JDM B16 (slkleltlclh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slkleltlclh &raquo;</TD></TR><TR><TD CLASS="quote">low fluid?</TD></TR></TABLE>
Check that first for sure. Check and see if your axle seal is leaking or has gone out.
Old Dec 16, 2006 | 12:41 PM
Default Re: Clutch Issue with my JDM B16 (nsxmatt)
Yep, it was the axel seal. I pulled everything off today to fix it.
When I went to put the new seal on, it was too small. I got one for a 94 GSR. That is saposto fit right? I thought all B series trannies used the same parts????? I'm gonna order a seal for a del sol Vtec on monday.
Old Dec 16, 2006 | 02:42 PM
bumpin it up!!!!
Wich axel seal for a jdm B16 trans?????????
nmb16a
Transmission & Drivetrain
Jan 31, 2010 07:43 PM
jwshilli
Jul 14, 2009 03:02 PM
tippz
Mar 13, 2008 09:48 AM
allmotorbl
10
Jun 12, 2006 03:18 PM
honda4674
Oct 24, 2005 07:39 AM
