EK...already has GSR suspension...want to go 5 lug...what do i need?
I'm new to the whole 5 lug conversion side of the EK so I'm not sure if I'm ahead or behind with already having a GSR suspension on the car. Will I just need hubs and discs? the 5 lug instructions ive found thus far are sketchy. thanks for the help.
lucas
lucas
usually when u purchase the 5lug conversion, it comes with everything needed for a direct bolt on. in ur case, the only thing u will reuse on ur ek is the rear lower control arms unless u get a ctr 5lug and it has the ctr lcas on em. otherwise, a usdm itr 5 lug will be a direct bolt on to ur car.
The hub swap's far cheaper. You will have to switch to Legend/ITR brakes though. ITR hubs are wider than GSR by a touch so, the old brakes won't fit.
bigger brakes, different variety of rim selections, ability to run different calipers(nsx and spoon) and bling!
i got my 5lug because of the rims i have for it. 15x7 volk te37 in bronze for 5x114.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HTn00b »</TD></TR><TR><TD CLASS="quote">what is the purpose of 5 lug, seriously</TD></TR></TABLE>
I have R/Legend brakes on my 4 lug. You have to mill the brake bracket .080" and re-drill Prelude rotors. I used to have big problems on the track with overheating the brakes, with the upgrade, I never have brake issues.
