how to hollow out a cat
Old Dec 15, 2006 | 01:43 PM
chadalac1712's Avatar
Default how to hollow out a cat
how do you hollow it out? thx
Old Dec 15, 2006 | 01:47 PM
bart2546's Avatar
Default Re: how to hollow out a cat (chadalac1712)
Easiest way would be to unbolt it, but depending how your cat is set up, you may need to hack saw it off an inch or two down the pipe away from the cat, and then you want a really long heavy duty screw driver (flathead) or a cro-bar. Just stick the screw driver or cro-bar into the car and swirl it around abit and it should knock the honeycomb type stuff out. Or if you have someone who's really good at welding, cut the cat in half, hollow it out and have that person re-weld it back together.
Old Dec 15, 2006 | 01:49 PM
is buying a nice new 1 worth it? or should i just hollow it
Old Dec 15, 2006 | 02:23 PM
TJ500's Avatar
Default Re: (chadalac1712)
street car? if so use a high flow cat, gains are marginal unless you have a sick build and your car will stink, high flow cat ftw.
Old Dec 15, 2006 | 03:02 PM
doood's Avatar
been there done that
Default Re: (Gundamboy)
just leave it alone. it's not like your making enough power to benefit from it.
Old Dec 15, 2006 | 03:05 PM
95ProjectEJ1's Avatar
Default Re: (doood)
Unbolt your cat, turn that thing vertically, put one foot on each end of the flange and grab and drill and have at it (make sure you secure it, if it catches it will spin and mess up your shins). Worked for me and it only took about 10 minutes. A long screw driver will help push out the small chunks.
Old Dec 15, 2006 | 03:54 PM
bart2546's Avatar
Default Re: (95ProjectEJ1)
I wouldn't buy a brand new one to ruin, I mean if you're gonna buy a brand new one I'd put it on and use it as it's supposed to be used. Myself I'd yank one from another car, (or use your own old one) and hollow that one.
Old Dec 15, 2006 | 03:55 PM
sicones's Avatar
replace the cat, gutting it will just leave you with a loud, smelly car with a CEL (if OBD2)
Old Dec 15, 2006 | 06:20 PM
InvaderTrax's Avatar
I got a Magnaflow cat and I like it
Old Dec 15, 2006 | 07:40 PM
suspendedHatch's Avatar
Default Re: (InvaderTrax)
Gget a long broomstick, climb up a ladder, shove it up your ***, then jump.
A hollowed cat causes turbulence resulting in restriction in the exhaust resulting in a decrease in power. Search. Even a test pipe gives you a max of 2 hp on a highly modified engine. Is it worth the damage to the air we breathe?
Bad smell, black bumper, crappy exhaust noise, reduction in the ozone layer...
Old Dec 15, 2006 | 07:45 PM
HTn00b's Avatar
201.143.204.122
Default Re: (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Gget a long broomstick, climb up a ladder, shove it up your ***, then jump.
Bad smell, black bumper, crappy exhaust noise, reduction in the ozone layer...</TD></TR></TABLE>
*thud*
Old Dec 15, 2006 | 08:19 PM
Syndacate's Avatar
Long flathead screw driver, drive it in and out, hollow that **** out.
Easiest way by far.
Old Dec 15, 2006 | 09:40 PM
axtran's Avatar
just get a test pipe and save yourself the hassle if you are this hardcore
DRE6906
12
Nov 23, 2010 10:42 AM
JDM00SI
Oct 15, 2005 09:14 PM
streetspeed607
Apr 21, 2004 08:06 PM
Audio28
Nov 16, 2002 03:38 PM
randomwalk101
Nov 7, 2001 12:36 PM
