problem
Old Dec 15, 2006 | 12:16 PM
h22_guy's Avatar
Default problem
hey i put my H22 civic away the other week and it was such a nice day out i decided to take it out for one more burn started fine smoked a bit but i figured that was normal sitting around for a bit took it out drove it worked find then when i was putting it away that radiator started smoking and it was dripping rad fluid on the floor what could be the problem hadda leave pretty quick couldnt stay around and figuree it out i was thinking maybe there was some water in the rad fluid and it froze but before i put it away i topped it off with proper rad fluid so i dunno i doubt it would have froze maybe a leak ?
Old Dec 15, 2006 | 12:22 PM
THC07's Avatar
Default Re: problem (h22_guy)
so whats your question? wheres the Tech?
look for yo leak dude. findout where its leaking, and if you have any Qs then ask, after you search.
good luck
H22s
Old Dec 15, 2006 | 12:31 PM
h22_guy's Avatar
Default Re: problem (THC07)
alright is there any chance i could have cracked the block
Old Dec 15, 2006 | 12:37 PM
THC07's Avatar
you gotta see where its leaking from first. i dout its the block, hose probly
Old Dec 15, 2006 | 12:39 PM
h22_guy's Avatar
alright man thanks ill give it a check sometime soon
Old Dec 15, 2006 | 12:47 PM
beaneg6's Avatar
If you cannot find the leak then you can buy a flourescent dye that you can put into you radiator that can help you detect the leak under a black light..
Old Dec 15, 2006 | 12:51 PM
h22_guy's Avatar
alright
BlkAsH
Mar 15, 2016 12:52 PM
CiViC I2aCeI2
12
Jan 4, 2006 12:25 AM
Semi-automatic
Jul 30, 2004 10:09 PM
hatchback19
Apr 2, 2003 05:32 PM
