GT30R on low compression built b16 spool times and whp numbers with it
Old Dec 15, 2006 | 05:40 AM
b18sihatch's Avatar
Default GT30R on low compression built b16 spool times and whp numbers with it
ok so i am thinking of going with a gt30r .60ar / .63ar and was wondering what you guys think the spool times and who numbers might be on 15-20psi motor has 8:1 compression ratio.
Old Dec 15, 2006 | 06:50 AM
WickedHonda00's Avatar
Default Re: GT30R on low compression built b16 spool times and whp numbers with it (b18sihatch)
I think the spool will be very gradual on the B16 using pump gas. From 4k-8k+ the torque line should look like the f(x), which is a 45 degree line from bottom left to top right. Point being, it will peak right at 8k, which in turn means you will constantly accelerate at a faster and faster rate until you shift to the next gear. A very good turbo for traction in my opinion. Granted, all of this is speculation with the assumption that you have a very good manifold like lovefab or fullrace and a solid boost setting, no creep, no leaks, etc. Just to give an example, here's a good link...https://honda-tech.com/zerothread?id=1773907
This car made 341whp on 8psi on a completely stock block, which is stupid awesome. It also made 217ft/lbs which is enough to give you a nice rush when at 6.5k+. He has the setup posted, so observe the results, and try to match that setup. If your already using higher quality pistons, although at lower compression, they should be nearly the same results since the pistons are much lighter than stock units. (Typically). Hope this helps.
I also think you'll be coming really close to maxing that turbo out at 20psi. I'd say 375+whp easy at 15psi, and perhaps close to 450whp if things turn out great.
Modified by WickedHonda00 at 9:23 AM 12/15/2006
Old Dec 15, 2006 | 07:18 AM
b18sihatch's Avatar
Default Re: GT30R on low compression built b16 spool times and whp numbers with it (WickedHonda00)
im running
full race prostreet ramhorn manifold
full race prostreet 3'' downpipe
full race Backdoor intercooler 11x3x20
full race civic intercooler piping for the backdoor intercooler
Old Dec 15, 2006 | 08:21 AM
Yeah, at 15psi I would expect somewhere around 400whp, maybe 425whp. IMO. I'm just speculating though. Full-Race doesn't mess around, but that character that pulled off 340whp w/ a 30R and a LoveFab was a freak setup, and especially rare to see.
Old Dec 15, 2006 | 03:35 PM
b18sihatch's Avatar
thats exactly what im looking for, 15psi with 400whp that would be great
Old Dec 15, 2006 | 04:08 PM
B.'s Avatar
B.
400 HP Club
full boost around 4-5k but well worth the wait.... and you'll make good numbers with that turbo and a solid tune .... I think the guy up top is talking about my setup aswell LOL...
Old Dec 15, 2006 | 05:11 PM
IntegraTypeR's Avatar
here is a similar setup: http://www.youtube.com/watch?v=FdijTTxWwWk
i think you will be very happy with the results
Old Dec 15, 2006 | 06:48 PM
a1320addict's Avatar
Default Re: GT30R on low compression built b16 spool times and whp numbers with it (IntegraTypeR)
I think you'll be very happy with it, I enjoy it more then the 28rs I had on the car. The 28rs was awesome, but it spooled too damn quick!
My setup:
http://forums.evans-tuning.com...=4065
Old Dec 18, 2006 | 10:47 AM
Default Re: GT30R on low compression built b16 spool times and whp numbers with it (B.)
yes, I was talking about your beast. I've been telling people that the GT30R is the best damn turbo for the B16 hands down. You finally proved that for me. Thanks.
I'm actually building up my block with very similar parts, except that I'm using the GT35R (yes, the bandwagon)..and boosting it moderately (15psi). Hoping for 425+whp. That's enough for me to be happy...
Old Dec 18, 2006 | 01:14 PM
b18sihatch's Avatar
i went gt35r and am running like you 15psi daily but 25psi track HAHA wonder what kinda numbers that would pull
Old Dec 19, 2006 | 09:47 AM
we'll see. My head is coming from IB. 300+CFM w/ high lift NA cams. I'm hoping my mid-range will set new records. I ain't worried about top-end since the turbo is entirely too big for my motor anyways. I'm also using the LoveFab Shorty EQ mani in hopes of quick spooling.
Old Dec 19, 2006 | 09:57 AM
ExVtec's Avatar
I believe Jeff Evans did an experiment regarding spool rates compared to compression and displacement.
Whereas compression only effected power output not spool characteristics while spool was effected by displacement ie bore size.
Old Dec 19, 2006 | 10:53 AM
b18sihatch's Avatar
Default Re: GT30R on low compression built b16 spool times and whp numbers with it (ExVtec)
on full races website they have a car showing 650whp with 81.5bore they are using the stg3gt turbo kit.... basicly the same motor i am using and same kit, altho i dont plan on pushing that kinda power, at least not yet!
Old Dec 19, 2006 | 11:31 AM
noboostedEGo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WickedHonda00 &raquo;</TD></TR><TR><TD CLASS="quote">I think the spool will be very gradual on the B16 using pump gas. From 4k-8k+ the torque line should look like the f(x), which is a 45 degree line from bottom left to top right. Modified by WickedHonda00 at 9:23 AM 12/15/2006</TD></TR></TABLE>
don't you mean f(x) = x?
haha sorry, math major here....
Old Dec 19, 2006 | 11:34 AM
Default Re: GT30R on low compression built b16 spool times and whp numbers with it (noboostedEGo)
Yeah, I didn't want to throw an equation out there. I figured I would get criticized about that. But yes, (the function of X) is what I meant. I'm no math major, but I've had Calculus a few times. Once in high school, once in college. Or other words... Y=X. For those who never saw past high school algebra.
Old Dec 19, 2006 | 07:13 PM
b18sihatch's Avatar
well 81.5mm bore making 650whp is pretty impressive.
Old Dec 19, 2006 | 07:21 PM
B.'s Avatar
B.
400 HP Club
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">well 81.5mm bore making 650whp is pretty impressive.</TD></TR></TABLE> street driven? if so I hope you dont like 1st, 2nd or 3rd gear.. lol
Old Dec 20, 2006 | 05:47 AM
b18sihatch's Avatar
well it definitly wouldnt be a street driven car with 650whp lol, but still the ammount of whp produced at that bore is pretty nice.
esurds
25
Apr 15, 2010 05:33 AM
airslammedcivic2
Apr 8, 2010 12:18 AM
Boostage
Apr 11, 2005 07:11 AM
Yellb16crxsi
May 4, 2003 01:16 PM
pagong
Jul 7, 2001 07:47 PM
