compression problems
Old May 12, 2002 | 12:17 AM
mick's Avatar
Default compression problems
a few months ago i noticed a sudden lack of power in my teg, got a compression test done and got 120/180/180/180 (120 in cylinder 1); leakdown test concluded the same, somethings broken.
we've just removed the head on my b16a1 this arvo, had a look at the head gasket, and it seems to be fine; anything else that could be wrong? (whats the likelyhood that it could be piston rings?)
cheers, michael
Old May 12, 2002 | 04:11 AM
Prelude Vtec 23's Avatar
Default Re: compression problems (mick)
You could have bent valves, have you checked that??
Old May 13, 2002 | 02:14 PM
mick's Avatar
Default Re: compression problems (Prelude Vtec 23)
nope - ill have a look!
anything else that may be wrong? warped head?
Old May 13, 2002 | 04:35 PM
Chiovnidca's Avatar
A leakdown test works pretty good for narrowing down low compresion problems.
Old May 13, 2002 | 06:39 PM
Doogie Howser's Avatar
Default Re: compression problems (Teken)
id say rings
Old May 13, 2002 | 11:31 PM
mick's Avatar
yeah - when i had the car running lots of air came out the oil filler cap - what would this indicate?
no - i didnt try putting some oil down the cylinder when doing the compression test, will try that though when i get it back together, thanks for the tip!
when i had the leakdown test done it indicated cylinder 1 was 10% loss, the rest were 5%.. with bubbles comin out the radiator cap, so one would assume the gasket? (however this doesn't seem to be the case); any other ideas?
much appreciated, cheers
[Modified by mick, 8:34 AM 5/14/2002]
Old May 14, 2002 | 09:48 AM
Chiovnidca's Avatar
Air bubbles in the cooling system during a leakdown test indicate a bad head gasket, a cracked head or a cracked cylinder.
[Modified by Chiovnidca, 9:36 PM 5/14/2002]
Old May 14, 2002 | 06:03 PM
Lyonel's Avatar
Hey Teken!
Here are some pics when we removed the head from Mick's DA6.
Old May 17, 2002 | 07:55 AM
mick's Avatar
im starting to wonder whether the problem is actually in the block, though it wasn't putting out any noticeable black/blue smoke..
going to get it pressure tested/check out the value seats in cylinder 1 next thurs, i'll soon find out whether its the head or the block i suppose..
thanks for all your input guys, much appreciated
Old May 19, 2002 | 12:26 AM
mick's Avatar
teken: yeah man, stock headers suck ***
Old May 23, 2002 | 02:09 AM
mick's Avatar
right, got the head pressure tested/leak tested today, and it turned out fine!! valve seats are fine.. so im erring more on the side that the head was warped due to overheating? (problem is this isnt consistent with the condition of the head gasket (which was fine, no scorching or anything))
Old May 23, 2002 | 02:26 AM
LSyellowREX
Guest
Posts: n/a
the only way i can think of a warping head is by pooring water on it after its been run hard... my guess is that you have a cracked cylinder or your #1 cylinder ring isnt sealing combustion properly... check both of those...
Old May 26, 2002 | 08:44 PM
mick's Avatar
Default Re: compression problems (LSyellowREX)
yip! gonna check rings in cylinder 1 tomorrow.. ill keep you posted!
Old May 28, 2002 | 03:38 PM
mick's Avatar
got piston 1 out, and the rings are fine!!!!!!!!
so im stumped.. anyone got any ideas? the head wasnt majorly warped, valves are seated properly, the rings in the cylinder that was down are fine.. only other thing i can think of is a warped block, but this seems unlikely since the head wasnt warped..
confused!
Old Jun 7, 2002 | 07:43 AM
mick's Avatar
Default Re: compression problems (EVIL Teken)
got it all together again, gonna get a compression test done soon - will let u know of results, it seems better so im hopin for the best..
djsimm89
Jun 7, 2013 12:14 PM
turbo_ef4
Feb 17, 2006 11:55 AM
Droppedatbirth!
15
Feb 2, 2004 06:36 AM
aracer69
Nov 16, 2003 06:14 PM
bleebdat
Oct 8, 2002 03:52 AM
