Installing SI lip. QUESTION
There should be two screws (there should be little indentions on each end of the lip and bumper so you can tap those easily in the correct spot. Other then that, the mounting hardware you can buy at the dealership. That's not the cheapest way to go, but at least you'll know it is on good. I used the two screws on each end, and some double-sided tape and zip ties along the middle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CRX_PLEASE »</TD></TR><TR><TD CLASS="quote">oh so u didnt use the hard ware on the bottom?</TD></TR></TABLE>
Nah, just two zipties and really sticky double-sided tape is more then enough. The mounting hardware kit isn't really worth it.
Honda uses the same mounting bolts on all their civics/tegs and accords. a trip to the junk yard should net you enough to do the job 2 times over for less than $5.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y »</TD></TR><TR><TD CLASS="quote">Honda uses the same mounting bolts on all their civics/tegs and accords. a trip to the junk yard should net you enough to do the job 2 times over for less than $5.
those clips fit in your pocket....
</TD></TR></TABLE>those clips fit in your pocket....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMej1 »</TD></TR><TR><TD CLASS="quote">those clips fit in your pocket....</TD></TR></TABLE>
So do a lot of things at Wal-Mart but, I didn't think telling the guy to steal them would be a good idea.
scrap1ngsr
Jul 11, 2005 08:07 AM
johnny hatchback
Apr 9, 2002 12:51 AM
