Honda S2000 Honda S2000
Tuning the AP2 for ALL-MOTOR(NA), while staying obd2
Old Dec 14, 2006 | 09:39 PM
Azcheron's Avatar
Default Tuning the AP2 for ALL-MOTOR(NA), while staying obd2
anyway to tune an AP2 with a full NA build, higher redline, different VTEC engagement, higher compression, bigger injectors
and still keep the car OBD2 for emissions?
Old Dec 14, 2006 | 09:44 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: Tuning the AP2 for ALL-MOTOR(NA), while staying obd2 (Azcheron)
Keep the small lobes on the cams conservative, tune(higher redline, earlier VTEC engagement), keep your catalytic converter on. Leave it to bolt ons.
Old Dec 14, 2006 | 09:57 PM
Azcheron's Avatar
Default Re: Tuning the AP2 for ALL-MOTOR(NA), while staying obd2 (FR-MOB: Projekt)
well, i can get around the catalytic converted, i dont care about that
i want to know if i can tune the car for NA and keep it OBD2?
what would i use to tune it?
Old Dec 14, 2006 | 10:21 PM
immortal's Avatar
Banned
greddy e-manage ultimate
Old Dec 15, 2006 | 12:17 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azcheron &raquo;</TD></TR><TR><TD CLASS="quote">well, i can get around the catalytic converted, i dont care about that
what would i use to tune it?</TD></TR></TABLE>
You did mention emissions, so I thought you were keeping the cat. In California, you get the dyno, the sniffer AND the OBD2 plug-in.
Old Dec 15, 2006 | 04:29 AM
Scot's Avatar
Default Re: Tuning the AP2 for ALL-MOTOR(NA), while staying obd2 (immortal)
can you change the redline with Emanage? I know with AEM you can.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by immortal &raquo;</TD></TR><TR><TD CLASS="quote">greddy e-manage ultimate</TD></TR></TABLE>
Staying NA will definately limit the HP. I would imagine 300hp would be about it, with the best tune, toda header, head work, etc..... hardly worth the trouble when you can get better hp cheaper by taking a different route.
Old Dec 15, 2006 | 10:43 AM
Azcheron's Avatar
Default Re: Tuning the AP2 for ALL-MOTOR(NA), while staying obd2 (Scot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scot &raquo;</TD></TR><TR><TD CLASS="quote">can you change the redline with Emanage? I know with AEM you can.
Staying NA will definately limit the HP. I would imagine 300hp would be about it, with the best tune, toda header, head work, etc..... hardly worth the trouble when you can get better hp cheaper by taking a different route.</TD></TR></TABLE>
well, that depends on your goals for the car and what it is you what your car to do
NA power delivery is much different than turbo's
Old Dec 15, 2006 | 10:50 AM
* B A N N E D *
NA power delivery is much different than turbo's</TD></TR></TABLE>
You're telling that to one of the worst track ****** we have here?
Have not talked to anyone running the E-MU, so you'd have to wait for an answer.
Old Dec 16, 2006 | 07:04 AM
Chris F's Avatar
I used to run Emanage (non-ultimate). It was pretty neat. With any piggyback system, though, your redline is staying right where it is.
I suppose there's really no other solution? No one has chipped the S2000 ECU yet? Really, that's what you need, unless you think you can get a Hondata from another application to work.
I'm looking for the answer to the same question, but more for Honda Challenge ECU requirements. The ECU has to be from "any" model of Honda, and can be chipped, but has to be a modified OEM ECU and not Motec.
Hopefully someone will figure it out
Old Dec 16, 2006 | 07:50 AM
IrishAP1's Avatar
Default Re: Tuning the AP2 for ALL-MOTOR(NA), while staying obd2 (Chris F)
What about a stroker kit?
Old Dec 16, 2006 | 08:07 AM
Chris F's Avatar
Default Re: Tuning the AP2 for ALL-MOTOR(NA), while staying obd2 (IrishAP1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IrishAP1 &raquo;</TD></TR><TR><TD CLASS="quote">What about a stroker kit?</TD></TR></TABLE>
You replying to me?
Well, if it were legal, great but it's not, and it's a PITA to tune anyway (no chipped ECU's)
Old Dec 16, 2006 | 08:42 AM
IrishAP1's Avatar
Yea i was replying to you, i didn't know it was illegal though.
Old Dec 16, 2006 | 05:21 PM
Scot's Avatar
yes, but with Turbo there will actually be additional power.... NA is very limited and expensive.
Lighten the car, throw some gears in it and the BPU and call it a day..... if you aren't happy, buy an EVO....ahahha.... just messin...
nycgsr
Apr 23, 2017 07:09 PM
Bangher4$
Engine Management and Tuning
Mar 12, 2009 06:42 AM
3litre190
Aug 29, 2007 04:24 PM
wrEcKed_LX
Apr 3, 2006 11:21 AM
