FAILED REF HELP!!!!!!!!
Old Dec 14, 2006 | 09:03 PM
Ryan15's Avatar
Default FAILED REF HELP!!!!!!!!
OK First off heres my results
15mph- HC max 89, gross polluter 277, measured 129-fail
CO (%) max .53, gross polluter 2.03, measured .79-fail
NOx max 708, gross polluter 1944,measured-200 Pass
25mph- HC max 54, gross polluter 227, measured 31- Pass
CO (%) max .51, gross polluter 2.01, measured .01- Pass
NOx max 746, gross polluter 1744, measured 3584-gross polluter
The motor is a 96 b18c1 usdm gsr motor, it does have a milled head thinner head gasket and high compression valves bring it to 11:1 compression according to c-speed, the ecu is a p28 (in p72 casing of course), I was wondering if it would help me pass if i put the usdm type r program in my ecu, right now its some program called j`s racing which im guessing is not helping pass emissions at all, o and all this test was done on 91 octane with 3 bottles of heet(methyl alchohol. I fany one has any ideas so i can get this smogged please let me know i need to get this done soon.
Ryan
Old Dec 14, 2006 | 09:21 PM
BuddhaSiR's Avatar
Default Re: FAILED REF HELP!!!!!!!! (Ryan15)
i would diffently try a stock ecu program. The increased compression is going to make NOx higher. Retarding the ignition timing should lower NOx a tad. Make sure your cat is warmed up plenty by driving it on the freeway for a little while.
At 15mph your a little on the rich side, maybe check your o2 sensor and cat. converter.
At 25mph looks like it went lean, CO went down but NOx went up.
Old Dec 14, 2006 | 09:43 PM
Ryan15's Avatar
its like a 15 minute drive there on the freeway buit it sat around for a good half an hour before the test i think i am going to do the usdm type r program, and the timing is at 14 btdc, ill check my o2 sesnor i dont know if my cat is bad, im thinking about putting an evo cat on it if i fail my pretest after i check my o2 and get another ecu program
90cb4door
Jun 24, 2010 03:44 PM
gtz
73
Mar 13, 2008 07:22 PM
m_shake
10
Jan 22, 2008 10:25 AM
acuteviet
Sep 10, 2006 01:59 PM
17
Jul 30, 2006 09:09 PM
