b16 IM vs ITR IM
Old Dec 14, 2006 | 05:52 PM
Drew17th's Avatar
Default b16 IM vs ITR IM
what is the difference??? ITR flows better right?????
Old Dec 14, 2006 | 06:09 PM
Brick Top's Avatar
Default Re: b16 IM vs ITR IM (Drew17th)
with stock cams, the myth is the b16 p30 manifold over powers the itr manifold throughout the entire rpm range. not sure if different bottom ends affect this.
Old Dec 14, 2006 | 06:18 PM
Drew17th's Avatar
Default Re: b16 IM vs ITR IM (brick top)
well im gonna have jdm itr bottom end completely rebuilt with fully built supertech head with high compression valves with m22x cams....
Old Dec 14, 2006 | 07:15 PM
Del Soouulll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew17th &raquo;</TD></TR><TR><TD CLASS="quote">well im gonna have jdm itr bottom end completely rebuilt with fully built supertech head with high compression valves with m22x cams....</TD></TR></TABLE>
ITR manifold ported, or Skunk2 Pro series would be good
Old Dec 15, 2006 | 01:18 PM
gotboost562's Avatar
Default Re: b16 IM vs ITR IM (bLack*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bLack* &raquo;</TD></TR><TR><TD CLASS="quote">
ITR manifold ported, or Skunk2 Pro series would be good</TD></TR></TABLE>
Whom do you suggest doing the port job? Import Builders? Is there a difference in the JDM and USDM ITR manifolds? Thanks.
Old Dec 15, 2006 | 01:29 PM
jdmB18CT-R's Avatar
Default Re: b16 IM vs ITR IM (gotboost562)
Dont forget whitfield racing CNC P73 manifolds..
And just because you got a bigger/better manifold dont forget the TB, like MAXBORE porting..
Old Dec 15, 2006 | 01:35 PM
Default Re: b16 IM vs ITR IM (jdmB18CT-R)
What about the Edelbrock Victor X?
Old Dec 15, 2006 | 04:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotboost562 &raquo;</TD></TR><TR><TD CLASS="quote">What about the Edelbrock Victor X?</TD></TR></TABLE>
i suggest this manifold for a 2L motor
Old Dec 15, 2006 | 10:53 PM
UncleD's Avatar
With the M22x cam, you're gonna want an intake that flows well on the top end. In your personaly situation, go with the type r. And the Victor X should be out of the question, MUCH too large for your motor as it is now.:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bLack* &raquo;</TD></TR><TR><TD CLASS="quote">i suggest this manifold for a 2L motor</TD></TR></TABLE>
Old Dec 16, 2006 | 02:30 PM
Drew17th's Avatar
Default Re: b16 IM vs ITR IM (clean rice)
so for my personnal set up go with the type r manifold???? good cuz i just bought it for $40 from a friend lol... thats what i call deals.....
Old Dec 18, 2006 | 09:25 PM
Drew17th's Avatar
bump!
Old Dec 18, 2006 | 10:08 PM
UncleD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew17th &raquo;</TD></TR><TR><TD CLASS="quote">so for my personnal set up go with the type r manifold???? </TD></TR></TABLE>
For sure, you got a DEAL son!
Old Dec 19, 2006 | 07:13 AM
SkankyEJ7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">With the M22x cam, you're gonna want an intake that flows well on the top end. In your personaly situation, go with the type r. And the Victor X should be out of the question, MUCH too large for your motor as it is now.:
4doortypeR
14
Mar 26, 2010 03:35 PM
Turboed00EM1
Nov 19, 2007 11:31 AM
mike_paz17
May 23, 2007 07:37 PM
-KangaRod-
Oct 2, 2003 01:13 PM
preludacris
Apr 24, 2003 05:15 PM
