ball joints and poly bushings, what do you know about them????????????
Old Dec 14, 2006 | 03:04 PM
philosofy1's Avatar
Default ball joints and poly bushings, what do you know about them????????????
i'm finishing up my bushing upgrade and now i have came to a hault. i can't seem to figure out how to install the poly boot on the ball joints.
i doesn't fit with the original boot on. and i cut the boot out (from the old ball joint i removed) and not only does it it flimsy, but i can't seem to get the ring clip on to hold the boot in place. this is getting quite fustrating.
Old Dec 14, 2006 | 04:08 PM
BOOSTED RIVAL's Avatar
Default Re: ball joints and poly bushings, what do you know about them???????????? (philosofy1)
I did my prothane bushing all around but that ball joints cover I can't get it on too. The stock one have a line around the cover so the ring could lock on but the after market don't. My best bet if you go with oem on that ball joint or if it not tear don't touch it.
Old Dec 14, 2006 | 04:16 PM
philosofy1's Avatar
Default Re: ball joints and poly bushings, what do you know about them???????????? (BOOSTED RIVAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTED RIVAL &raquo;</TD></TR><TR><TD CLASS="quote">I did my prothane bushing all around but that ball joints cover I can't get it on too. The stock one have a line around the cover so the ring could lock on but the after market don't. My best bet if you go with oem on that ball joint or if it not tear don't touch it.</TD></TR></TABLE>
that's just it, it doesn't take much to tear them. i was thinkingoff just putting it over the boot then installing them, but i'm afraid that the boot will pop underpressure with the poly boot over it.
MMMM...FRUSTRATED! anyone else has any other good suggestions?
Old Dec 14, 2006 | 05:07 PM
philosofy1's Avatar
BUMP
Old Dec 14, 2006 | 05:15 PM
eda6's Avatar
leave the oem boot on if it's ok. if there's a tear then i suggest a new ball joint.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
this is getting quite fustrating.</TD></TR></TABLE>
toss em in the garbage
Old Dec 14, 2006 | 05:31 PM
MasterKwan's Avatar
Default Re: ball joints and poly bushings, what do you know about them???????????? (eda6)
You can buy new OEM boots from Honda too.
I have a poly bushing kit myself. I'm basically replacing 10 bushings from the whole kit because there are a number of bushings that HAVE to be either rubber or spherical bearings. You switch them to poly and the handling gets twitchy.
Like the trailing arm main bushing and the rear LCA bushings.
Old Dec 14, 2006 | 05:51 PM
philosofy1's Avatar
Default Re: ball joints and poly bushings, what do you know about them???????????? (MasterKwan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan &raquo;</TD></TR><TR><TD CLASS="quote">You can buy new OEM boots from Honda too.
Like the trailing arm main bushing and the rear LCA bushings. </TD></TR></TABLE>
yeah the rear trailing arm i was just planning to replace it with a new rubber one.
as far as for the ball joints, you see it's a whole suspension off of a 95 GSR original my cousin had the gsr, wrecked it, bought a 92 hatch, then sold it never using the suspension.
since the suspension was in great shape it was supposed to go on his hatch but never did. so it sat around his garage for about 4 years, then i bought a hatch 2 years ago and he sold it to me about a year ago.
so i decided to change out all the bushings, ball joints, bearings, etc. figured it a lot easier once it's out versus installing it then removing it again to make a repair.
so much for my story. but i appreciate the time and suggestions you guys put in.
thanks!
Old Dec 14, 2006 | 06:19 PM
MasterKwan's Avatar
It's a good plan. Ball joint replacement sucks. I never could get the press on it correctly to push them back on. Pushing them out's pretty easy.
xaaronex
Suspension & Brakes
Mar 28, 2010 04:14 PM
CWBETB
Jul 20, 2007 09:23 AM
philosofy1
Suspension & Brakes
Dec 15, 2006 08:42 AM
rasinhell
Feb 23, 2005 03:47 AM
ratherbewalking
Jan 29, 2003 08:45 PM
