sent wrong injectors?!?!?!
Old Dec 14, 2006 | 02:57 PM
Baodalazi's Avatar
Default sent wrong injectors?!?!?!
i went and tried to put the injector plugs into the injectors today and found out they didnt fit !!! heres pics if somebody can figure out what these injectors are actually for
Old Dec 14, 2006 | 03:02 PM
Baodalazi's Avatar
as you can see in the injector pics theres a piece of plastic thats between the two metal prongs that blocking the plug from going in please help guys
Old Dec 14, 2006 | 03:44 PM
unknown0001's Avatar
Default Re: sent wrong injectors?!?!?! (Baodalazi)
Call RC Engineering instead of waiting for somebody to reply?
Old Dec 14, 2006 | 05:37 PM
Baodalazi's Avatar
ahaa yah i sent them a email oo ididnt know they had a number lemme go find it
Old Dec 14, 2006 | 05:40 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (Baodalazi)
Looks like an OBD0 injector.
Old Dec 15, 2006 | 05:00 AM
Natural Aspirations's Avatar
Default Re: (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Looks like an OBD0 injector.</TD></TR></TABLE>
Measure the resistance between the 2 contacts on the injector. 2-4 ohms it is a peak and hold obd-0 injector 12-14 ohms it is a saturated injector that works with 92 and up ecu's. If it is a peak and hold style you will have to use a resistor box for your 92- up ecu. If you need a resistor box you can PM me I have one.
Old Dec 15, 2006 | 06:24 AM
b19coupe's Avatar
You can cut out the little plastic tab inside the injector and it will plug in. Never done it myself, but I have seen it done successfully.
Old Dec 15, 2006 | 06:26 AM
NA_B18C1's Avatar
yours looks totally fatter then my RC injectors. wrong ones..call RC and give them the injector numbers..they can look up and tell you which car it's for
boosted k20's Avatar
Default Re: sent wrong injectors?!?!?! (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">You can cut out the little plastic tab inside the injector and it will plug in. Never done it myself, but I have seen it done successfully.
thats exactly what i did w/ my precision injectors. just take a sharp blade and cut that tab out in the middle of the two prongs. the clips will then fit w/ no problems
Old Dec 15, 2006 | 07:08 AM
Default Re: sent wrong injectors?!?!?! (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">
thats exactly what i did w/ my precision injectors. just take a sharp blade and cut that tab out in the middle of the two prongs. the clips will then fit w/ no problems</TD></TR></TABLE>
Heck yeah that sounds like a great idea if you don't mind frying your obd-1 with obd-0 injectors.
Measure the resistance before you go modding the injector. If it is the correct impedance then you can modify it to work.
Old Dec 15, 2006 | 07:19 AM
b19coupe's Avatar
Default Re: sent wrong injectors?!?!?! (Natural Aspirations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations &raquo;</TD></TR><TR><TD CLASS="quote">Measure the resistance before you go modding the injector. If it is the correct impedance then you can modify it to work.</TD></TR></TABLE>
Look at the pic-those are RC SL 310cc injectors. Saturated OBD1 injectors
Old Dec 15, 2006 | 11:24 AM
um if im run n 1000cc dont u *think* i know that they r low impedance and i put in a resistor box
Old Dec 15, 2006 | 12:27 PM
Baodalazi's Avatar
oo its a saturated injector so would i need a resister box for it? as for the plastic clipping what do i needa use to get it out successfully? without breaking anything ahha
Old Dec 15, 2006 | 01:37 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
you can also purchase the very nice RC injector plugs (right way to do it)
Old Dec 15, 2006 | 09:43 PM
Baodalazi's Avatar
oo do yo have a link to the site for th e injector plugs
Old Dec 16, 2006 | 04:17 PM
DYNO-PRO
ummm they are not on the RC site?
Old Dec 16, 2006 | 11:57 PM
Baodalazi's Avatar
i dont kno the rc website i tried to type diff names in but came up with company websites
Old Dec 17, 2006 | 06:24 AM
b19coupe's Avatar
http://www.rceng.com/prices.htm
Old Dec 17, 2006 | 06:53 AM
Default Re: (b19coupe)
use a box cutter and slice that tab off. dont be scared!!!!
The Dirty EJ1
Apr 8, 2013 12:42 PM
tonylovesjdmEF9
Engine Management and Tuning
Sep 16, 2010 10:17 PM
alfee
May 19, 2005 11:57 PM
Sleepin'
Feb 11, 2003 04:02 PM
lucas569
Apr 13, 2002 06:13 PM
