Need help on water leak...
Old May 11, 2002 | 09:50 PM
CimorelliCRX's Avatar
Default Need help on water leak...
Okay, well we are done putting hte motor in, and hooked up all the lines, and yes all the lines are hooked up, that we know of, and can see. But the problem is we have a leak somewhere. When we fill the radiator up, its leaking water out of like the block, towards the bottom somewhere. Its on the back is where its leaking from. We think there is like a little whole where a freeze plug should be or something, and there isnt one there. But we arent sure. Anyone have this problem or any idea what it can be, we are stumped, as usual when i post here..
Default Re: Need help on water leak... (CimorelliCRX)
Ohh yea, BTW this is on a ZC....
Old May 11, 2002 | 09:52 PM
EP3_05's Avatar
There is the water pipe that runs across the back of the block...maybe it somehow was damaged?? Are any of the coolant hoses on the manifold dry rotted and leaking onto the block??? Just some thoughts
Old May 11, 2002 | 10:09 PM
Default Re: Need help on water leak... (91civic)
We will check into them tomorrow, it was too dark and we dont have any flash lights or drop lights to use, all dead, hehe.
Old May 12, 2002 | 08:22 AM
ttt
Old May 12, 2002 | 12:08 PM
Magick211's Avatar
no its not the water pipe, its leaking from the very bottom of the block, i already checked that pipe steve
Old May 12, 2002 | 01:46 PM
Default Re: Need help on water leak... (CivicBoyZC)
Well Ill be a monkey in ****, lol. Im about to give you a call Mike. Any other suggestions?
Tour991
Honda Civic (2001 - 2005)
Apr 16, 2013 07:11 PM
krysted9354
Jan 27, 2009 03:34 PM
hb_guy
Feb 24, 2006 01:45 PM
loudassVTEC
Jan 3, 2006 02:10 PM
surephase
May 10, 2004 05:44 AM
