low mpg after oil change?
Old Dec 14, 2006 | 12:37 PM
aikuu427's Avatar
Default low mpg after oil change?
i have a 95 civic lx sedan. [77,000]
i've searched and foudn the guy with the h22 13mpg civic but i have a completely different scenario. other threads were about maintaining a good mpg.
so about a week ago i took my car into this new place because they were offering a discount for oil changes [10w30] and a free 12 point inspection. nothing was wrong with the car and i was maintaining about 22-23 mpg because i drive half freeway and half city. the problem now is that after i filled up my tank, i noticed that im getting lower mpg. ive only gotten about 100 miles for about 3/4 of a tank and i usually get about 220miles for a full tank. the weather has been cold lately but can weather significantly drop my mpg that much? my car is bone stock and i installed new subs recently. i had the subs inside my car before the oil change but they werent wired up.
anybody have any suggestions on whats going on? thanks for your time!
Old Dec 14, 2006 | 01:30 PM
tha_badguy's Avatar
check ur dipstick?
did they just pour in fresh oil on top of ur old oil?
any cels?
oil light?
Modified by tha_badguy at 2:54 PM 12/14/2006
Old Dec 14, 2006 | 01:34 PM
Padawan's Avatar
Darth ModerVader
Default Re: low mpg after oil change? (aikuu427)
Well, for future reference the manual calls for 5W-30, though the 10W-30 shouldn't be an issue. It's quite possible your latest fill-up was a bad tank of fuel, which could be affecting your mileage.
Old Dec 14, 2006 | 01:43 PM
aikuu427's Avatar
Default Re: low mpg after oil change? (Padawan)
i think they just poured fresh oil on top of the old oil. they said that the 10W-30 was the "recommended." im waiting for this tank to finish to see how much miles ive lost and hope that its just the bad tank of fuel =[. thanks for the advice!
anybody have any other suggestions?
Old Dec 14, 2006 | 02:05 PM
Filliam H. Muffman's Avatar
again, check your dipstick.
you could have too much oil in there
Old Dec 14, 2006 | 03:36 PM
aikuu427's Avatar
i am a noob but yes, ive checked the oil and it does seem to be a bit over where it should be.
how am I suppose to take the oil out? -__-'
Old Dec 14, 2006 | 03:48 PM
97civicdx's Avatar
buy a oil drain pan from auto store, 17 mm socket will loosen the oil pan drain bolt, then drain it out. Good time to change filter too. Drain used oil into a milk container and bring to recycling center or auto store
Old Dec 14, 2006 | 03:59 PM
matt9987's Avatar
Default Re: low mpg after oil change? (97civicdx)
probably bad fuel
Old Dec 14, 2006 | 04:03 PM
tha_badguy's Avatar
Default Re: low mpg after oil change? (matt9987)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt9987 &raquo;</TD></TR><TR><TD CLASS="quote">probably bad fuel</TD></TR></TABLE>
Now was that really necessary...
<U>UP YOUR POST COUNT SOMEWHERE ELSE!</U>
Old Dec 14, 2006 | 05:09 PM
aikuu427's Avatar
thank you to all of you for your time.
longskate87
13
Nov 5, 2014 02:13 PM
bigsnorlax
Apr 17, 2009 03:10 PM
ucb
Apr 24, 2003 01:31 AM
io_burn
Jan 5, 2003 10:19 AM
mickey513
Sep 28, 2002 01:10 PM
