am ready to retest?
if you guys failed emissions .... how would you know when to go retest
I have retarded timing
cleaned eacv thoroughly
changed dirty spark plugs
changed/thickened oil
I am running higher oct gas(it aint empty so putting alchy in it is not an opt)
air filter is young and clean
am I ready to try again?
(I am thin on cash now so keep that in mind)
how do I know when it is done?
What exactly did your car fail on? There is high co2, ho2??? and one other one here in CO anyway? and on the emissions sheet they will normally tell you what to do if you fail in one or more of the readings.
oops
sorry
I failed on CO
CO 2.31% ...................limit 1.2%
HC 208ppm.................limit 222ppm -----------and last year I had 18ppm here!
CO2 12.45%.......................no limit
sorry
I failed on CO
follow this chart: http://www.firstfives.org/faq/smog/smog_faq.html
I was even thiinking of removing the cover of my dpfi so it had no resitance to air
but that would screw with vacuum and make things worse probly?
off to parts store
off to parts store
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt »</TD></TR><TR><TD CLASS="quote">follow this chart: http://www.firstfives.org/faq/smog/smog_faq.html</TD></TR></TABLE>
Thanks alot 4 that chart tilt
is that in the FAQ?
It should be
is that in the FAQ?
It should be
dem0nk1d
Jul 7, 2006 11:11 AM
