Aem underdrive pulley question.....
Old May 11, 2002 | 09:15 PM
02EXACCRDCPE5SPD's Avatar
Default Aem underdrive pulley question.....
hello......around how many horsepower does aem underdrive pulley increase? is the difference noticeable? and i hear that if you get it, all of your electric functions become messed up....is that true?? please help me. Thanks.
Old May 11, 2002 | 09:19 PM
Accord94DX's Avatar
Default Re: Aem underdrive pulley question..... (02EXACCRDCPE5SPD)
3hp at most.
Old May 11, 2002 | 09:44 PM
B12uceHuy's Avatar
Default Re: Aem underdrive pulley question..... (Accord94DX)
Pulley dont do much for your car... all it does is change the rotation speed of your alternator, PS, etc... what ever that belt is connected too. its like the gears on ur mountain Bike the bigger the diameter the less Rotation the smaller the diameter the faster the rotation. Hope that helps
Old May 12, 2002 | 01:21 AM
s2ktonv's Avatar
Default Re: Aem underdrive pulley question..... (B12uceHuy)
Ya know, I wonder if the pulley will effect power for my sound system???
Old May 12, 2002 | 08:06 AM
unltdacc12's Avatar
Default Re: Aem underdrive pulley question..... (s2ktonv)
i have aem pulleys.. they helped out a little bit.. not much though.. as far as systems.. at idle my lights used to dim when the bass would hit, but i fixed that by using 2gauge wire and a cap..
Old May 12, 2002 | 01:56 PM
s2ktonv's Avatar
Default Re: Aem underdrive pulley question..... (unltdacc12)
Cool I'll prolly end up doing that too
Old May 12, 2002 | 02:09 PM
SOHCArchangel's Avatar
well if you 'must' have a pulley do not get the underdrive ones, get the stock sized ones from unorthodox racing
Old May 12, 2002 | 02:34 PM
Mike P.'s Avatar
25 Year Member
Default Re: Aem underdrive pulley question..... (SOHCArchangel)
aiite thanx well want da car to look alil high class with da wood dash
Old May 12, 2002 | 04:32 PM
Brandon's Avatar
Life is Suffering
There would not be any benefit to getting a regularly sized pulley. As for the amount of power it makes, expect 4-5hp in an Accord. This may not sound like much, but the power would increase across the board, improving acclereation more than an intake or header would on their own. The AEM's work better because they do not affect the crank pulley, they only change out the others, leaving the harmonic dampener in place.
Old May 12, 2002 | 11:25 PM
s2ktonv's Avatar
How much do those unorthudox run$?
[Modified by s2ktonv, 12:25 AM 5/13/2002]
GreenMachineRex
13
Apr 26, 2004 12:53 PM
Gobliins
Feb 23, 2004 04:30 PM
o_Rage_o
Jan 16, 2002 08:39 PM
