car got slower?
Old Dec 14, 2006 | 09:11 AM
BMaDOHC's Avatar
Default car got slower?
How's it goin guys. This past weekend I was doin some racing with my buddies and I was getting beat pretty good by my buddy with a gsr. he's got all the bolt ons with no computer upgrade and he was getting me by a half car. A couple months back at the track I was beating him by 3-4 tenths at the quarter mile. The only difference now is I put jdm 16's on my car compared to the stock 15's. I know your car slows down with bigger wheels but by that much? now he's beating me by a couple of tenths? The car still feels good but it has to be slower. Have you guys noticed this with wheel size difference? I don't know, guess it's time for some drag rads on some 15's. what you guys think.
Old Dec 14, 2006 | 09:14 AM
Dave_B's Avatar
Wheels/Tires will only make a difference if the O.D. changes.
Old Dec 14, 2006 | 09:16 AM
BMaDOHC's Avatar
Default Re: (Dave_B)
so my car should be just as fast with the 16's on it.
Old Dec 14, 2006 | 09:21 AM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B (aka Short Stack) &raquo;</TD></TR><TR><TD CLASS="quote">Wheels/Tires will only make a difference if the O.D. changes.</TD></TR></TABLE>
Wheel/tire weight will also make a difference.
Old Dec 14, 2006 | 09:43 AM
Ed 341's Avatar
Default Re: car got slower? (BMaDOHC)
Well think about that Best Motoring video where a JDM ITR punishes an SIR (GSR?) in the 1/4. If both cars are healthy and the GSR is stock (or equivalent mods) your race should be identical.
Old Dec 14, 2006 | 09:44 AM
Dave_B's Avatar
Default Re: (Mugen Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">
Wheel/tire weight will also make a difference.</TD></TR></TABLE>
True, but I think OD would matter more than weight because your changing the gearing essentially.
Old Dec 14, 2006 | 09:48 AM
cmdr430's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">
True, but I think OD would matter more than weight because your changing the gearing essentially.</TD></TR></TABLE>
both will matter OD and weight.....especially rotational weight....it will take more energy to move a heavier and larger wheel.....
Old Dec 14, 2006 | 09:49 AM
totsie7944's Avatar
change your spark plugs
Old Dec 14, 2006 | 10:11 AM
Dave_B's Avatar
Default Re: (cmdr430)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">
both will matter OD and weight.....especially rotational weight....it will take more energy to move a heavier and larger wheel.....</TD></TR></TABLE>
But that much? That's why I suspect the OD has changed a bit. I can see how rotational weight makes a difference, but not the difference he's talking about.
Old Dec 14, 2006 | 10:29 AM
dcash13's Avatar
there cannot be that big of a weight difference in stock 15s vs stock 16s can there?.. and unless you have some crazy sized tire the OD shouldnt be affected..
Old Dec 14, 2006 | 10:31 AM
dcash13's Avatar
p.s.
if you want to sell the stock 15s or even the 16s.. pm me...
Old Dec 14, 2006 | 10:39 AM
cmdr430's Avatar
But that much? That's why I suspect the OD has changed a bit. I can see how rotational weight makes a difference, but not the difference he's talking about.</TD></TR></TABLE>
my guess is that he is spinning more off the line or has crappier tires than before.... of course it is hard to tell from what info he has given.....
Old Dec 14, 2006 | 10:47 AM
DVC2008's Avatar
My guess is your boy has parts he aint telling you about hahahah
Dave_B's Avatar
my guess is that he is spinning more off the line or has crappier tires than before.... of course it is hard to tell from what info he has given.....</TD></TR></TABLE>
Good point, traction!
Old Dec 14, 2006 | 11:09 AM
nafreak's Avatar
put yer 15s back on and then see what happens.....
Old Dec 14, 2006 | 12:29 PM
GO-FIGHT-KILL's Avatar
You should be destroying the GSR... I raced one with full Skunk2 head package, nice intake system, nice exhaust system, CTR pistons and a V-AFC tune (Not the best, but still, better). And I pulled 2 cars... With my A/C on, and a bad Oxygen Sensor.
Do some basic maintenence, that might be the issue.
Old Dec 14, 2006 | 12:50 PM
exies's Avatar
Maybe it's not that your car slower, but his car got that much faster!
But post your tire size, maybe you increased the OD accidently. As mentioned before, try putting the 15's back on.
Old Dec 14, 2006 | 02:35 PM
itr1244's Avatar
Default Re: (exies)
time to do compression test and leak down
my car got slower over time and when i did compression test one of my cylinder on my head was leaking
210 210 190 210
so. i rebuilt the motor
and your buddy might have got the cams without letting you know? lol
Old Dec 15, 2006 | 06:53 AM
Utilitarian's Avatar
Default Re: car got slower? (Miss Type R Tia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miss Type R Tia &raquo;</TD></TR><TR><TD CLASS="quote">i had gotten myself new tires that are supposedly good for handling..they are BFGs and i got them installed at discount tires...the guy who put my wheels back on had only put 4 lug nuts back on for the front right side because he said that one might be stripped and he didnt want to mess it up...now that side wheel is making noises only when i turn to the left.....what do i do? </TD></TR></TABLE>
Sounds like they didn't tighten the lugs to the right torque specs. With one lug missing/broken you shouldn't notice such a sound.
Just tighten all the lugs to 80 ft./lbs.
I got ten miles out of Danville and starting hearing a creaking noise only to find out I hadn't torqued one of my front wheels.
Old Dec 15, 2006 | 07:03 AM
waddy41's Avatar
Default Re: (itr1244)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">time to do compression test and leak down</TD></TR></TABLE>
x2
how many miles on the r?
Old Dec 15, 2006 | 01:39 PM
BMaDOHC's Avatar
Default Re: (waddy41)
65k on the R, compression and leak down are fine. vehicle gets drivin not even once a week. I think it must have been traction because his car was getting me at the end of first and going into second. dam new england cold weather!!
Old Dec 15, 2006 | 05:39 PM
SiR99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DVC2006 &raquo;</TD></TR><TR><TD CLASS="quote">My guess is your boy has parts he aint telling you about hahahah </TD></TR></TABLE>
This is most likely the situation.
Gsr doesnt just pull on an itR... probably has cams and a tune with everything else you mentioned.
Old Dec 16, 2006 | 10:56 AM
itr1244's Avatar
it's alright. both your car and your buddy's gsr's slow
mine too lol
lome1232
17
Mar 8, 2010 10:21 AM
DC5mike
Apr 5, 2009 06:43 PM
kidrolla
Honda Civic (2006 - 2015)
16
Jun 25, 2007 03:45 PM
coot_er
10
Nov 9, 2005 04:31 PM
..::91TEG-G2::..
Oct 3, 2004 08:21 PM
