electrical prob?
so i was gonna add a headunit to my 1996 accord lx. it had no stock harness. there was only the wires to connect so i was going to connect the wires to the headunit wires but i couldnt see the colors at night so i ended up not connecting anything after i had taken all the electrical tape off. then i started my car n noticed my clock n gauges werent turned on. what happened?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r1ch »</TD></TR><TR><TD CLASS="quote">so i was gonna add a headunit to my 1996 accord lx. it had no stock harness. there was only the wires to connect so i was going to connect the wires to the headunit wires but i couldnt see the colors at night so i ended up not connecting anything after i had taken all the electrical tape off. then i started my car n noticed my clock n gauges werent turned on. what happened?</TD></TR></TABLE>
this is why you don't work on car when you are..well..i don't want to call you stupid but..ar..let's use the term not capable.
check the fuse, you might ran into multiple circuit together thus will 1)burn a fuse 2)fry some electronic stuff.
let's check the fuse and start from there.
CRXed
Nov 10, 2006 07:45 PM
