looking for 900rr front wheel
Old Dec 13, 2006 | 06:43 PM
turbopete's Avatar
Default looking for 900rr front wheel
exactly what the title says. With rotors. Would like a newer model, 98-99 for the larger rotor size.
Old Dec 13, 2006 | 06:47 PM
marmaladedad's Avatar
You sure about wanting only the 98-99 900RR? The 900RR is a 16" wheel, whereas the F3 wheel is a 17, and a direct fit for the 900RR. Could you just buy the larger rotors?
Old Dec 13, 2006 | 07:01 PM
turbopete's Avatar
Default Re: (marmaladeboy)
If you read the post, it said 98-99 had bigger rotors. I want the bigger rotors. I am aware that the wheels are all 16 inch
Old Dec 13, 2006 | 07:04 PM
Default Re: (turbopete)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbopete &raquo;</TD></TR><TR><TD CLASS="quote">If you read the post, it said 98-99 had bigger rotors. I want the bigger rotors. I am aware that the wheels are all 16 inch </TD></TR></TABLE>
Ok, just making sure. G/L with the search.
Old Dec 14, 2006 | 02:41 AM
turbopete's Avatar
bump. 16 in front whee/tire combo give me a little more room to lower the front end. Provides intercooler clearance. thats why I dont want an f2 wheel
Old Dec 14, 2006 | 04:27 PM
Rogue_F4i's Avatar
Default Re: looking for 900rr front wheel (turbopete)
Check out http://www.cbrforum.com
Might have some luck over there.
Old Dec 14, 2006 | 05:01 PM
turbopete's Avatar
Default Re: looking for 900rr front wheel (Rogue_F4i)
Thanks Rogue, I will
Old Dec 15, 2006 | 08:20 PM
85's Avatar
85
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbopete &raquo;</TD></TR><TR><TD CLASS="quote">exactly what the title says. With rotors. Would like a newer model, 98-99 for the larger rotor size.</TD></TR></TABLE>
Get an f3 front wheel, i used to have a 900 and the 17 was like night and day not to mention you will havea better tire selection
Old Dec 15, 2006 | 09:35 PM
turbopete's Avatar
Default Re: looking for 900rr front wheel (hks85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hks85 &raquo;</TD></TR><TR><TD CLASS="quote">
Get an f3 front wheel, i used to have a 900 and the 17 was like night and day not to mention you will havea better tire selection</TD></TR></TABLE>
Already has a 17 in wheel on it from the factory. Read 3 posts up
Old Dec 15, 2006 | 09:56 PM
D Day's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbopete &raquo;</TD></TR><TR><TD CLASS="quote">Provides intercooler clearance. </TD></TR></TABLE>
i have a feeling that is going to be fun.
Old Dec 15, 2006 | 11:07 PM
turbopete's Avatar
Default Re: (D Day)
Old Dec 16, 2006 | 12:09 PM
D Day's Avatar
i can now see why you dont want the 17.
lilo_goki
29
Aug 4, 2009 07:54 PM
K20boiZ
Aug 6, 2007 08:21 PM
glulude
May 1, 2007 04:57 PM
chinkybangbang
Oct 23, 2006 09:25 PM
jb1813
Oct 9, 2002 10:38 PM
