what compression would this be "pixs inside"
Old Dec 13, 2006 | 06:41 PM
cashshoes's Avatar
Default what compression would this be "pixs inside"
ok i am putting something together but want to know the compression on this first before i put it all the way together i have a b16 block that i put ls pistons and rods in and i am putting on a gsr head would any one on hear know the compression of this i already know it is high because at top dead center the piston sticks out of the block a little bit i have a pic
Old Dec 13, 2006 | 06:43 PM
Jim Truett's Avatar
Default Re: what compression would this be "pixs inside" (cashshoes)
That will hit the head.
Old Dec 13, 2006 | 06:45 PM
sniggler316's Avatar
Default Re: what compression would this be "pixs inside" (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">That will hit the head. </TD></TR></TABLE>
That's what I thought
Old Dec 13, 2006 | 06:49 PM
cashshoes's Avatar
you think
Old Dec 13, 2006 | 07:09 PM
ABK's Avatar
ABK
Default Re: (cashshoes)
why would you do this. lmao.
Old Dec 13, 2006 | 07:15 PM
chrisw85's Avatar
i think you can put a b18 crank into a b16 block (basically stroker kit sorta) but cannot put ls rods into a b16 cause of the length? or is it that just because the pistons on the LS are taller than b16 ones?
Old Dec 13, 2006 | 07:18 PM
cashshoes's Avatar
yeah it will hit the head just tryed well back to the drawing board thought it would rais compresion
Old Dec 13, 2006 | 07:20 PM
cashshoes's Avatar
ls and gsr rods are longer on a b16 crank but i didnt think it would be that long
Old Dec 13, 2006 | 07:31 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cashshoes &raquo;</TD></TR><TR><TD CLASS="quote">ls and gsr rods are longer on a b16 crank but i didnt think it would be that long</TD></TR></TABLE>
3mm longer, or .118".
Old Dec 13, 2006 | 07:35 PM
YeeJ6's Avatar
b16a's have a lower deck height than b18's.
Old Dec 13, 2006 | 07:51 PM
EJgsr's Avatar
Default Re: what compression would this be "pixs inside" (Spoonspeed)
you could put 2 or 3 head gaskets on it...
Old Dec 13, 2006 | 07:57 PM
YeeJ6's Avatar
Default Re: what compression would this be "pixs inside" (USDMej1)
haha. wouldnt be suprised if a thread like that pops up in a few weeks lol
Old Dec 13, 2006 | 09:28 PM
spork motorsports's Avatar
* B A N N E D *
conformation on a b18 crank oem stroker kit for the b16 a block??????????
Old Dec 13, 2006 | 09:46 PM
blinx9900's Avatar
according to zealautowerks your all WRONG, your compression will be 12.2:1 BUT if your using the b18 crank (you never said which crank your using) then yes it will hit, but if you have b16a crank it will work...
http://www.zealautowerks.com/
Old Dec 13, 2006 | 11:36 PM
doood's Avatar
been there done that
Default Re: (spork motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports &raquo;</TD></TR><TR><TD CLASS="quote">conformation on a b18 crank oem stroker kit for the b16 a block??????????</TD></TR></TABLE>
you can use an ls crank and rods in a b16 block with custom pistons with raised wrist pins
Old Dec 15, 2006 | 08:51 AM
Jim Truett's Avatar
Default Re: what compression would this be "pixs inside" (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">according to zealautowerks your all WRONG, your compression will be 12.2:1 BUT if your using the b18 crank (you never said which crank your using) then yes it will hit, but if you have b16a crank it will work...
http://www.zealautowerks.com/</TD></TR></TABLE>
Have you ever built a motor?
Look at the pics. The piston sticks way above the deck. Even with a B16 crank it won't work because the LS piston compression height is the same as the B16 pistons, but the rods are 3mm longer. Get off of your PC and go do something.
Old Dec 15, 2006 | 08:54 AM
komat's Avatar
my question is where is the cylinder 3 piston at ?
Old Dec 15, 2006 | 09:10 AM
Heylookits shawn's Avatar
Default Re: what compression would this be "pixs inside" (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">my question is where is the cylinder 3 piston at ?</TD></TR></TABLE>
he probably only put one on, just to check clearance. a good choice, because that would be mighty nasty if he were to start that thing up
Old Dec 15, 2006 | 09:12 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: what compression would this be "pixs inside" (Heylookits shawn)
Look up the TECH43 kit. Bad idea.
EJ1_203
10
Sep 28, 2007 04:28 PM
bOOsTiNSoHcVtEc
Jul 6, 2005 06:34 PM
powerfulperformance
Feb 28, 2005 10:08 PM
AllMoToRB18c
Jun 29, 2003 02:56 PM
