help!! my instrument cluster and other int. lights wont come on
Old Dec 13, 2006 | 04:57 PM
1baddturbosi's Avatar
Default help!! my instrument cluster and other int. lights wont come on
92 accord, its been acting up for a while but when i go to turn on my headlights the instrument cluster and other lites dont illuminate.
its prob a switch but what is it??
Old Dec 13, 2006 | 05:08 PM
mrhonda2u's Avatar
Default Re: help!! my instrument cluster and other int. lights wont come on (1baddturbosi)
headlight dimmer switch? if unplugged will also cause others not to light. so if its bad?
Old Dec 13, 2006 | 05:16 PM
Default Re: help!! my instrument cluster and other int. lights wont come on (mrhonda2u)
no thats good. when they use to work, id turn the parking lites on and they would be on, but when i turned my headlites on they would go out. i bet its a switch but i dunno what
Old Dec 13, 2006 | 06:25 PM
hondadude's Avatar
what are the "other" lites that don't work? Have you checked the fuse panels?
Old Dec 13, 2006 | 06:37 PM
Default Re: help!! my instrument cluster and other int. lights wont come on (hondadude)
the instrument cluster and the climate controls and everything else but the clock and the cd player. i doubt its a fuse because sometimes when i turn on the car and flip the headlights on they wont work, but when i let it sit for a bit then try it again they eventually turn on. they would kinda flicker dim and bright the past few days.
i have no idea
Old Dec 13, 2006 | 08:55 PM
JuniorSpades's Avatar
It sounds like your multiplexer is shot. Should be on the drivers side attached to your fuse box. I have an 02 accord, and it was the EXACT SAME PROBLEM you were having. The multiplexer is Blue on my fuse box. I'll post pics later.
Old Dec 14, 2006 | 06:31 PM
Default Re: (JuniorSpades)
anyone else have any idea??
Old Dec 14, 2006 | 07:40 PM
hondadude's Avatar
Default Re: (1baddturbosi)
headlight 'combo' switch
Old Dec 15, 2006 | 06:52 AM
Default Re: (hondadude)
that could be too. my friend works @ honda and he said the lead tech thinks it might be that my dimmer switch failed. ill let u know when i find out
1baddturbosi
Dec 19, 2006 02:48 PM
civicDX2178
Jun 5, 2006 02:22 AM
LOLyouhavefakewheels
11
Feb 1, 2006 07:28 PM
kaoticimports
May 31, 2004 08:53 PM
EGTeK
Mar 26, 2003 10:52 AM
