GOLDENEAGLE GASKET??????
Old Dec 13, 2006 | 04:25 PM
urtz's Avatar
Default GOLDENEAGLE GASKET??????
which way is the word up faced on an golden eagle vtec conversion gasket suppose to sit?i know its suppose to face up, but can you read it straight or when its upside down if you were looking at it from the front of the car?????????????
Old Dec 13, 2006 | 05:40 PM
Oyvind Ryeng's Avatar
Default Re: GOLDENEAGLE GASKET?????? (urtz)
It's my understanding that when the headgasket is lying on top of the engine block waiting to accept the head, the word "UP" will be readable straight forward, left-to-right.
Old Dec 13, 2006 | 07:46 PM
urtz's Avatar
Default Re: GOLDENEAGLE GASKET?????? (Oyvind Ryeng)
thats what i thought but it fits better with the word ''up'' upsidedown, basically turning it 180 degrees. i am confused because in my haynes manual the way the pic is, is the way i have it with the ''up'' is upside down.
Old Dec 13, 2006 | 07:57 PM
b19coupe's Avatar
The metal tag should be on the distributor side towards the front of the car, facing up.
Old Dec 13, 2006 | 07:58 PM
urtz's Avatar
i am also curious about the dowels between the head and block, i only have 2 dowels and they are the 2 in the front of the head. i dont hve the 2 in the back of the head. would this do anything or make a problem like a leak or something????
Old Dec 13, 2006 | 08:00 PM
urtz's Avatar
right! that would make it the way i thought it goes, but the "up" is upside down with it this way. thanks . screw it, i am leaving it this way.
Old Dec 13, 2006 | 08:01 PM
b19coupe's Avatar
You should only have two dowel pins.
Old Dec 13, 2006 | 08:05 PM
urtz's Avatar
Default Re: (b19coupe)
thanks buddy! i thought so. i need to make sure this goes right before i have to take it all apart again, you know. do you think i have to torque the head bolts down again after driving it a bit??
Old Dec 13, 2006 | 08:08 PM
b19coupe's Avatar
Default Re: (urtz)
Use ARP head studs with Moly lube, torque to 80 ft.-lbs, and forget about it.
Old Dec 13, 2006 | 08:10 PM
urtz's Avatar
i have brand new honda type r bolts, saved me about $50. i torqued them at 61 ft. lbs.
MigsD16
Engine Machining & Assembly
Dec 17, 2016 05:17 PM
strike1545
May 24, 2010 10:42 AM
Erwan
Sep 23, 2009 09:24 AM
3rdGteg
Oct 5, 2003 09:27 PM
civicracer1993
Jan 2, 2003 07:43 PM
